Window in progress, picture 1 (some length)
Bill Houghton, avoiding work in Sebastopol, CA
>Our new bathroom window is in, and LOML is quite pleased - it goes up and down easily, it's frosted glass so she doesn't have to say hi to the neighbors while using the bathroom, and it doesn't leak air like the old one. Installation has been the usual set of hassles in our old house, where nothing is ever as shown in the magazines (2x3 studs and previous window frame constructed unlike any I've ever seen before, both of which required me to cut down the window frame I'd carefully built, etc.), using my usual hybrid electron-death/sweat-of-brow techniques.
The main all-handtool-content part has been the crown. The pattern used on our house is bed molding (normally used, according to one website, "where walls and ceilings meet"). It's not a commonly available molding around here - last time I used any, well over a decade ago, I had to go to a guy who does specialized moldings out of his garage. This time, armed with a decade's more experience, I made it myself.
By great good luck, my one and only round base for the Stanley 45 happens to be the same curve as the hollow on the bed molding. So, the other afternoon, in about an hour's time, I free-handed a four foot section of molding using the No. 45 and No. 78 planes. After making each end of the stock with a bit of molding saved from the piece I bought ten years back, I started out cutting the reveal below the round part (which is the top - demonstrated in later pictures). I then cut the hollow before going back to cut the round by making successively smaller facets and finishing up with (yes, I cheated) sandpaper to fair the remaining little ridges. I planed the reveal at the bottom, and finished by flipping the stock over and planing the angles on the back.
The piece remaining after I installed the molding, below, will be more than enough to replace a missing return on another window.
Re: Window in progress, picture 1 (some length)
Window in progress, picture 2 - an old example
>The picture below is an example of the original molding.
Re: Window in progress, picture 3
>And here's the molding installed but not yet painted. I think it passes the block test.
The head flashing is rather funky - done with a hand seamer, because I don't have a sheet metal brake and didn't want to take the time to do an angle-iron-clamped-together one (note to Todd Hughes: there's no need, now, for you to mention that at last weekend's flea market you turned down a 48" brake for $5 because you didn't want to carry it to your car, and besides all you had was the Honda and you weren't sure it would fit in the back seat).
Langdon miter box convert
>I've been using a little Stanley 150 miter box for some years, cleaned up and mounted on a board so I could clamp it to the bench. I have a Millers-Falls Langdon Acme box, picked up at a garage sale for $15 a few years ago, but it's been in storage until I get the round tuits to clean it up.
I knew the 150 was too small for this molding, so I dragged out the M-F to give it a try. I sanded down the degree quadrant, which was unreadably rusty, and cleaned compacted sawdust from the rear post's slot (previous owner had been using a saw with insufficient depth from back to teeth), then gave it a try.
Wow. Not restored, with a slightly rusty Disston saw, not even bolted down, the box sang through the molding. Clean cut, accurate, no fuss. I can just imagine what it will be like when I've restored it.
Anyone need a Stanley 150 miter box?
Hey! That's hand hammered!
Scott Burr in Ben Lomond, CA
>Well Done! (or at least rare!).Ya still got your fingers? I tend to get a few cuts playing with sheetmetal. I think you did a fine job. Now the real fun part...painting it.
Retirement still fun?:^)
Re: Langdon miter box convert
Ernie Miller
>Looks good to me. SO now it's off to the next honey do.
Wiley Horne
>Really a beautiful job of reproducing the old molding, Bill. Please show the painted version when you're done (I need the inspiration).
Thanks, Wiley
Now I see it. - looks good.
Victor P
Hand bent, actually
>Hand seamers are like pliers with really wide jaws, usually used to set standing seams and similar sheet metal joints. They work somewhat - as can be seen, "somewhat" is an important modifier to the verb "work" - in making a bend from flat.
I bent tin for a living for about six months, a million years ago, and managed to get through with just one major cut. I deceive myself that I still have some of the skills. I do still love sheet metal soldering, though I don't have a good pot on which to heat the coppers.
