Re: LN's Cabnet Makers Scraper
V Parisian
>Their in between sized scraper... does anyone have personal experience with this tool. Good, Bad, ease of use etc?
SWMBO doesn't know it yet but looks like Santa came early this year. :>)
Victor - in Houston where we are trying to dry out a bit.
Re: Re: LN's Cabnet Makers Scraper
Dave Thompson
>Of the scraper planes this one (#85) is my favorite closely followed by a cheap old #80. This is in contrast to a #112 or #12 style.
One of the worst things while putting a final finishing on stock is to have a scraper plane skip or chatter. Skipping can be minimized by making sure one is applying adequate downward pressure, and of course have a sharp edge. The harder the wood, and the larger the blade, the more downward pressure must be applied. It's significantly more downward pressure than a bench plane requires. The #85 has a narrower blade than #112 or #12, requiring less pressure. I find it much more comfortable to work.
The chatter is reduced by better bedding and thicker blade. Narrow width of the blade on the #85 also helps becuase of less side leverage to start chatter flex of the blade. Chatter is much more frequent with a thinner blade #80 and #12.
enjoy,
Dave
David Charlesworth
>Interesting plane.
The only one which will scrape into a corner.
Fixed blade angle eliminates one source of error, blade setting easy with a sheet of paper under heel or toe on a flat surface.
It works very well.
Could be used on wide surfaces but I would then use slightly cambered blade to avoid tracks.
David Charlesworth
Andrew Dix
>FWIW The No. 85 was the first plane I ever purchased (along with the 60 1/2R). I will admit that I bought it because I thought it looked cool and wanted to start working with hand tools. Now I can safely say that after I learned to use the No. 85, I was hooked on planes, and have made a "few" subsequent purchases from Lie-Nielsen. So it was this plane that got me hooked on learning to use handplanes.
Thanks Dave, David and Andrew,
V Parisian
>I bought this tool on a bit of an impulse the other day, and before I actually touched wood with it ( I.E, still returnable as new), I thought I had better ask some of the actual users for opinions.
Work has been crazy busy of late, but I just may find some time this week end to "play" with it. Believe me, having this sit in the box unused has been agonizing.
Thanks again.
Victor - in Houston where the sun has come out and things are drying up nicely.
Re: Thanks Dave, David and Andrew,
Norman (Ottawa, Ont.)
>Victor,
I have that one ( Cabinet Maker's Scraper).
It is the fixed angle one and is just the right size for me,
not too small, not too large.
It also had the full-width blade as DC mentione ealrier.
I bought it on a excellent recommendation I had,
and it has served me well..
Norman
