Chair joint rehab question
woodburnbob
>My wife brought home an oak chair (sort of an antique side chair or desk chair of the same general design as the photo below). I don't think she noticed all the joints were cracked and loose. It's unuseable.
I disassembed the chair and was surprised the rail to leg joints were each comprised of three 3/8" dowels. In fact, all joints are dowelled. Some dowels are broken. I noticed an earlier repair had failed. It was poorly executed but drilling off-center 1/4" holes for new dowels secured with yellow glue intermixed with old crusty hide glue.
I've clean up all the joints, re-drilled dowel positions and so forth. I've stopped short of glue up because I started ruminating about whether to glue and clamp a few joints at a time versus gluing and clamping the whole chair at once.
At one point I thought of ditching the dowels and using biscuits and my biscuit cutter. But I don't think that's much of an improvement.
Now I'm thinking I should put a mortise on either side of each joint and use a separate "tenon". I'd think it would be the most mechanically rigid fix for the rail to leg joints.
Some years ago I tried rehabing some old dining chairs of the same vintage and dowel construction. After the yellow glue cured for a week or two I gently tested the joints and most of them cracked and fell apart. I just don't want to repeat history.
Any advice?
Re: Chair joint rehab question
I'd go with the loose tenons...
John in New Mexico
>About as good a fix as you could do. I wonder if there's any advantage to squaring the corners? I tend to like them that way, but don't have anything to back it up.
John
I concure...
Scott Burr in Ben Lomond, CA
>I think going with floating tenions would be the way to go. I think keep them rounded, a bit more contact/glue areas.
You could always glue some corner brackets and screw it to the legs from the back side. Ahhh thats cheating...
Re-engineering old furniture
jim reed @ tallahassee
>is often necessary. Sometimes the original design was just not strong enough. I would repair the dowel joints (they can be amazingly strong) and then add some glue blocks (not cross-grain!). Pretty chair. Good luck.
Ed Mulligan, Cape Cod
>For these situations I run a 1/64" oversize drill bit into the old hole to clean out the crud, use new dowels, and reglue with slow-set epoxy.
The epoxy has good gap-filling qualities. Using a slow-set formulation allows for plenty of time to glue up the whole chair in one session. Piecemeal gluing up a chair with loose joints will cause problems!
A strap clamp or two work well for getting even pressure on those loose joints and clamping the odd, nonparallel surfaces in a typical chair. You may need a clamp or weight to push down on the seat to counteract other clamping forces.
If a chair had significant value I would use other methods.
Ed
Re: Not cheating...
Glenn Madsen back home near San Francisco
>if it works and is hidden. A good corner block makes for a better chair joint. And a repaired old chair had better be safe.
In my family, where 'petite' is for the daughter-in-laws, chairs tend to be well engineered or firewood.
I like it Glen!
>"Well engineered or firewood" Well said!
