Have a question? Ask Woody!
Plane iron camber using the Tormek
Todd from San Jose
>Hi guys and gals,
What's the best way to put camber into plane irons (mild to wild)?
Last night, I used my relatively new-to-me Tormek to put camber into a jack plane iron. I was shooting for about 1/16". I used the standard jig (SVS-60?). I just applied a lot more pressure on the edges than the center.
Is there a better / more efficient way to do this? Do you recommend a different Tormek jig for this? I also have a scrub plane iron that would be difficult with this jig.
And how about the honing on water stones? I've got a crowned roller on order for my LV Mk II sharpening jig, hoping that will do the trick. I'm not sure if it will work for a variety of cambers.
Thanks
Todd
Re: Plane iron camber using the Tormek
thomd
>The LV roller is designed to allow you to do a wide range of cambers. It doesn't jig the lateral curve it just gets out of the way of it.
With grinders when doing visible amounts of camber I normally grind the profile at 90 degrees and then work back and forth until I pick up the edge.
For the subtler stuff I use the pressure technique. For smoothers I just do it on a stone. If you were taking a 1 thou shaving the total curve would be 1.5 thouish at 45 degrees, hard to see at all.
When I make things like scrub planes I usually start with a pattern off the computer that I print on the steel. Or I use a divider directly on the steel. I would saw and grind these eedges before heat treating.
John Aniano in NJ...
>Todd,
Do a search in the "Hand Tools Archives" - specify the day - May 3, 2004 and search for all the words "Blade radiusing jig for Tormek" and you will find a short guide I wrote for making just such a Tormek cambering jig. I can't figure out how to give you a direct link to the archived posting. Maybe Sir William can do this bit of magic...
John
David Charlesworth
>I have recently seen a jig mentioned by the firm that do the Tormek knock off, mustard like colour.
New Jig, have not tried it yet.
My standard Tormek jig is sloppy after much use and works well for small camber (approximation). Press hard on one corner and lift the opposite corner. Mind the fingers!
David Charlesworth
Here you go  *LINK*
Dan Donaldson
Blade radius jig
John Clifford
>Jet sells a jig that can camber up to a 3 inch radius for their Tormek knock-off. But it costs $99.
John Clifford
>Forgot to mention it will fit and work on the Tormek.
Tormek SVD-110 Tool Rest
Steve Elliott
>The SVD-110 is a flat jig that can be set at a range of angles, just like most grinder tool rests. I grind my plane blades with the regular Tormek jig, then relieve the corners with the SVD-110. Of all the specialty jigs for the Tormek, this is the one with the broadest range of uses.
Re: Plane iron camber using the Tormek *LINK*
>Hi Todd
I did write an article on jigs to camber blades using the LV Honing Guide Mk II. The link is below. This assumes you have the LV. Also LV now do have a jig for the guide that aids in honing the final edge to a camber, as my article also focusses on.
But the easiest (and cheapest!) way to grind a camber on a blade is to use a template. The template is nothing more than an outline of the blade with the radius of the camber filed/sanded off.
Usew it this way:
Really easy.
Advanced angles on the LV Honing Guide Mk II
Thanks everyone
Todd from San Jose
>To all,
Thanks for all of these useful suggesions- I never cease to be amazed at the quality of advice that I get on this forum.
I think I'll start by printing out a template, then trying the SVD-110 on the Tormek. Then, I'll see how well the LV Mk II crowned roller works with the waterstones. If I struggle with this, I may attempt a custom jig, as a couple of you have carefully described.
Todd
