Edge bead across the grain - Help!
Ray Drueke
>Hi,
I'm trying to add an edge bead to some window casing for an addition to an 18th century colonial (reproduction). With the grain all is well
but across the grain at the ends I'm getting tearout like crazy. The wood is pine and the plane (wood 1/4" edge bead)is as sharp as I can get it with scary sharp and a stone.
It also tears out with some poplar from the scrap bin and also both tear out when I try the molding head cutters on the p*w*r*d t*ble*saw.
Suggestions? I've thought of 'applied' bead to the edge but I'm
not sure how to do that!
Thanks,
Ray.
Re: Edge bead across the grain - Help!
Perhaps
jim reed @ tallahassee
>...you could figure out where the bead will be and make some preliminary cuts with a razor knife. I like to use a boxcutter. Sometimes I cut, plane, cut, plane, cut...until everything is done. Boxcutter works better than plane nickers. Good luck.
Have you tried a beader or...
Scott Burr in Ben Lomond, CA
>Scratch stock? They tend to work well in the situation your describing. I won't mention using a router here...yet.
Rob Millard
>Ray,
It is difficult to get a clean cut with a molding plane, going across the grain, in pine. It is even more difficult with a bead, since the sides of the bead are being scraped more than cut due to the geometry of the cutting edge. The bed angle also has an effect; a York pitch would be even more difficult to use on a soft wood, going across the grain.
A scratch stock, or beader, won�t work any better, and might be worse.
I�ve made faux cock-beads on drawer fronts, by carving the endgrain beads. Use a cutting gauge to establish the line of the bead, then deepen the cut with a sharp knife and using various gouges/chisels shape the bead. A very light sanding will remove the facets and clean up the bead.
Rob Millard
Warren in Lancaster, PA
>I have to agree with Rob. The easiest way do do this would be carving. Scratch stock and molding planes will make a mess of this, just as you have discovered.
I can't recall ever seeing a design like you have in pine around an 18th century window. If I saw this kind of cross grain bead on reproduction work I would think it 20th century design. 18th century joiners knew as well as you that this didn't work well and planned accordingly. Without knowing more about your design, I would suggest making a molding strip that is applied to the long grain and end grain and mitred at the corners or better yet, leave the end grain unadorned.
