ADVERTISE HERE - FREE TRIAL
problem plane shavings and dust colletion
bill tindall
>I have an Oneida 1.5 HP dust collector and use it to suck up dust from machines as well as everything on the floor, including those long stringy hand plane shavings. I noticed that I was loosing sucking capacity and took sections of the system apart to find where pipes might be blocked. I found these long stringy shavings hung on blast gates and anything that stuck out in pipes. But most of all they were entangled on the screen between the cyclone and air filter. It was astonishing the capacity I regained after removing all these obstructions. I won't try to pick up big wads of these shavings off the floor anymore.
Re: problem plane shavings and dust colletion
David Charlesworth
>Good point Bill, they are easy to pick up anyway.
David Charlesworth
Re: problem plane shavings and dust colletion *LINK*
>Bill
What if you added one of those garbage bin cyclones before the DC? - that should hold and store all the large shavings and prevent them getting to the intake of the DC. See below for a link.
Cyclone lids from Lee Valley
Just leave 'em on the floor...
Scott Burr in Ben Lomond, CA
>Like peanut shells at the hole in the wall bar every town has...;^)
Don't leave 'em on the floor...
Todd O. Cronkhite Maine Native, Presently Away
>They'll make it difficlt to find something like a small screw when you drop it. If however you have a bare concretre floor than you may want to leave them on the floor to cushion any falling tools.
They clean up easily, first grab up most of them with your hands, than use a broom and dustpan for the rest.
Todd O.
