Have a question? Ask Woody!
IndyFest Hand Plane Contest Details
>October 7th, 2006, IndyFest Planing Competition Details
The People in charge of the contest; Jim Shaver and Moses Yoder
Host; Ray Thompson
Event organizer; Jennifer Shirley
Sponsors and prizes donated (in alphabetical order)
Knight Toolworks ; (Steve Knight); Hand plane
Lee Valley ; Veritas Pullshave
Lie-Neilsen ; Iron #2 Bench Plane
Rockler ; $30 gift certificate
Tools for Working Wood; Gramercy Tools Beading Saw
Wiley Horne; Clark & Williams 22" Try plane
I plan on having the contest board and practice board set up by 10:00 am on Saturday October 7th. Contestants will have a 5 minute period of time at any time during the day up to 3 pm with the contest board to make their thinnest shaving for submission to the judges. The contest will be closed at 3:00 pm on Saturday October 7th, at which time any ties will be played out and final judging will take place. Winners must not be present to win, but it is best if they are so that group photographs can be taken. The prizes will be awarded as follows; 1st place chooses the prize of their choice first, 2nd place chooses next, and so on until all prizes have been awarded.
Here are the rules:
1. The contest is open to anyone attending the picnic, including the judges, though they will not measure their own shavings.
2. Any size or type of hand plane can be used. You may borrow, with the owners permission, a hand plane from anyone to make a shaving. Rental fees or sharing of prizes in the event your shaving beats that of the owner is not governed by these rules.
3. There will be a contest piece of wood and a similar practice piece of wood for contestants to tune up their planes. The contest piece will only be used for making shavings to be entered into the contest. Shavings from the practice piece or prior to the contest start are not eligible for entry. Contestants are expected to share the availability of the practice piece of wood equitably among the interested contestants
4. The contestant will be given one 5 minute period to produce the longest thinnest shaving possible from the contest piece of wood. Each contestant can make and collect as many shavings using as many planes as they want during this time, but only one shaving may be submitted for judging per contestant.
5. Only continuous length shavings can be submitted. The contestant should select the longest shaving they can make for submission. Shavings that disintegrate or break on the way to the judging area are not the responsibility of the judges and in such an event only the longest single piece will be judged.
6. No lubricants can be applied to the contest or practice board. Dry lubricants such as paraffin or wax may be placed on the plane.
7.Judging of shavings will consist of measurements taken at 9 places (see below) on each shaving and a measurement of length. Points are assigned for thickness and length. The thinner the shaving the lower the points. The longer the shaving the lower the points. Points for thickness and length are added together to determine the winner. The winner would be the lowest point total.
8. The shaving scoring system:
a. The thickness readings will be taken near each end of the shaving and near the middle of the length. Three readings will be made at each point at the edges and middle of the shaving. The thickest point at both ends and the center will be averaged and assigned a point score based on a table. If a shaving is only partial width at the ends or in the center, readings will be taken at the nearest full width area of the shaving. A table assigns a point value for average thickness ranging from .00050 to .00314 in .00001 increments, with a point value range of 1 to 265.
b. Length will be measured to the nearest inch by stretching out the shaving on a flat surface with out breaking the shaving. Points will be awarded inversely according to length. 1 point will be added for every inch less than the full length of the board.
c.. The lowest point shaving will win.
d. Copies of the scoring point tabulation will be made available in an Excel spreadsheet upon request.
9. In case of a tie, a run off will be held where the tied contestants will be given one opportunity to make the longest thinnest shaving they can from the contest piece in a single attempt. This run off shaving will be judged the same as before.
10. The contest is for fun and entertainment. The judging will be done as fairly as possible following the above guidelines. The judges are all volunteers and will do their best to be fair in their assessment of each shaving. Judges decisions are final.
11. These rules may be changed to insure fairness and to correct any errors or omissions discovered prior to the start of the contest.
13. Disputes will be handled out behind the woodshed and arbitrated by Jim Shaver, Ray, Thompson, and Mose Yoder.
*** My thanks to all of the people who made this possible. To John Weber who I think came up with the original planing contest, Lee Schierer who wrote these rules (I only made slight changes to the scoring system) , to Jim Shaver who will edit the rules and be in charge of the contest, to Ray Thompson for furnishing the place for this contest, to all the contestants and especially to all those who have donated prizes for this contest. Sponsors and prizes will be detailed in a description of the prizes for the contest, and also noted at the contest.
