Re: Help needed-planning my glue up and finishing
thomd
>Even wet sanding can be a problem because when it dries it needs to be tacked down.
To be commercially viable both from the point of view of "Quality" finish, and finishing speed, one needs to spray. If one sprays high VOC then one needs a spray booth with filtration (which I assume is not an issue here). Spray booths receive a lot of overspray, and the finish doesn't like any dust, so usually only spray goes on in spray booths.
(by the way: a) HVLP is down to 30 bucks for a gun where it used to cost hundreds, even here in Canada; b) the Dresner tape shows how to set up a spray booth with minimal materials. So does the KLausz tape.)
Any time one does a wet look finish the zero dust requirement is also in place.
Beyond that on has a lot of alternatives where a little dust isn't a big deal: hand applied oils, french polishing (wet sanding is integral to finish application), and brush-on finishes that may require hand rubbing. These things are slow and messy, but fire prottection is usually a bigger issue. By the way, fire is another reason not to mix initiators with fuel sources and sparks.
I remember seeing this statue of man as how he perceives the world through his senses, so hands and lips are enormous etc... In my perception of woodwork, finishing is a complete afterthought, like some spot in the middle of my back I can't feel. When it comes to selling it's a really big deal. Everything else is secondary. Now in natural wood furniture the wood sellection and some joinery plays a part in what the buyers sees too, so it's a little harder to separate the components. None the less a separate place for just spraying, or laying out work would be a real asset, I have never had that.
As far as grinding is concerned i would say two things: It does throw off a lot of localized dust that usually falls in the immediate area, however there is often a lot of engine blast from cooling fans. Also any overspray would be a problem. You don't even want to be walking into the area stuff is drying in to sharpen a tool, let alone the rest of it. Second is that the ideal grinder is a belt sander, and they are a little messier still, not bad but they produce fine grit, and the belts need a clean environment to remain sharp.
Anyway, there are so many issues; what a guitar maker needs is different from a chairmaker. Lots of room for personal adaptations.
