ADVERTISE HERE - FREE TRIAL
African Blackwood - which glue?
Mike Hamilton
>Was toying with the idea of making the Yeung Chan hammer from Andy Rae's book. Need a nice little hammer for plane blade adjustment. I have a couple Blackwood pen blanks that I might be able to use. The write up calls for gluing and wedging the handle into the head. I was thinking I'd use hickory or ash for the handle. Anybody know of any special issues with gluing Blackwood? It's still in wax so I haven't been able to feel if it's an 'oily exotic.' Anybody made this hammer? Any hints, gotcha's, etc?
I intend to sacrifice no electrons on this project. Keep your fingers crossed!
Regards,
Mike Hamilton
Plainfield, IN
Re: African Blackwood - which glue?
USE EPOXY
HC Sakman
Warren in Lancaster, PA
>African blackwood as the wood used for clarinets and oboes. Instrument makers and repairmen have used hide glue for many years on this material. I don't think there would be gluing problems with any glue. One advantage of using hide glue is that if it fails you can easily clean it off and reglue.
Although blackwood is a Dalbergia like cocobolo and rosewood, it is not as dense, not really oily, and not as strong. It is a little more brittle than rosewood; I'm not sure it would make the best mallet head.
Mike Hamilton
>Hi Warren,
This particular mallet/hammer is designed to have a small head with 1/8 inch brass pinned and epoxied to the end grain as a striking surface. Light tapping will be the limit of its use. Hopefully the brittleness of blackwood won't be an issue. Thanks for the input on gluing.
Has your last child picked a college yet?
Regards,
Mike Hamilton
Plainfield, IN
Jim in Burlington Ont.
>I've never found any of the African blackwood from A&M specialty woods to be fragile at all. I have glued several handles and knobs made from it with yellow glue and LV glue. It does take some super sharp tools to get a real smooth cut. No doubt the hardest wood I've planed. I'm not even sure you'll need a brass plate the wood is so tough.
blackwood -> Mozambique ebony/ not Gabone
Dave Thompson
>Hmmm... I wonder if it's the same wood. The last hardwood dealer I went to had "blackwood" in stock and I bought some. It was actually a wood I was quite familiar with from Eastern Africa which the East Africans called Ebony, commonly cultivated and exported from Mozambique. In North America, I've found alot of the hardwood stores use the term ebony with gabone ebony and it has properties like what you describe Warren, less dense, less oily and not quite as strong. Though, the Mozambique ebony, which I mentioned I've seen in North America called blackwood, is quite dense and oily, and not something I would consider at all fragile. Not sure I would use gabone ebony for a mallet head, but the Mozambique ebony (blackwood), I'd have no hesitation using for a plane mallet head. Mozambique ebony has heartwood that is nearly black with occasional subtle brownblack grain, and the sap wood is distinctly ivory/cream white.
FWIW, near me Mozambique ebony sells for $60/bf (twice that of cocobolo). In Kenya, I bought a turned and hand carved bowl from solid Mozambique ebony that came form 5"x10"x10" stock for something like $10. There's money to be made importing that stuff. I've forgotten the price of Gabone ebony, but I recall it was cheaper than even cocobolo.
enjoy,
Dave
Re: blackwood -> Mozambique ebony/ not Gabone
>The wood I was referring to (the one I think Mike has) was African blackwood (Dalbergia melanoxylon). It is referred to as grenadilla in the woodwind instrument trade. It grows in Mozambique and a few other African countries. Since I have played oboe and recorder all my life I have seen many cracks, dents, scratches, and chips in this material. I have also worked with it. One of the reasons it is used ahead of rosewood for these instruments is that it is slightly less dense and thus gives a more mellow sound.
The reason I posted was to point out some differences between African blackwood and its cousins in the Dalbergia genus like rosewood and cocobolo, which are more often used for mallets and which sometimes have gluing problems. African blackwood still is a dense wood and I think it will work for the Mike.
The genus Dalbergia is in the pea family along with acacia, locust and many others. The true ebonies are in the genus Diospyros along with persimmon; the genus Diospyros is in the ebony family. I think there is an unrelated wood from South America which also goes by the name grenadilla.
Yes, Dalbergia Melanoxylon
Dave Thompson
>Hi Warren, I guess we are talking about the same wood, Dalbergia Melanoxylon. Some googling turned up at least 8 different names this goes by, including African Blackwood and Mozambique ebony.
Regarding density, USDA FS-FPL lists the specific gravity of blackwood as 1.08. Cocobolo (dalbergia retusa) specic gravity is .80 to .98 Cocobolo has a hardness of 1136 janka. I can't find a hardness for blackwood. As comparison, walnut is around 1010, red oak 1260, hickory around 1820. Just handling the stuff, I would have thought it closer to hickory or harder.
I haven't used blackwood as a musical instrument or tool, so I'll defer to your experience regarding long term durability.
enjoy,
Dave
Re: Yes, Dalbergia Melanoxylon
David Charlesworth
>Dave,
I heard it described as the nearest thing to an engineering plastic, by a teacer at a musical instrument school.
My Inro boxes, were made from it and wear really well.
Book 1 page 98.
best wishes,
david Charlesworth
David, by 'engineering plastic', was
Wiley Horne
>your instrument maker friend referring to the wood's stability when dry?
Wiley
