OT - Plastic Cement / Adhesive
Paul Brandley
>I have a 1992 John Deere LX172 riding mower and the pivot points on the hood have broken. The hood is made out of plastic and costs $450 plus, installed.
I would like to know what type/brand of adheasive, cement, autobody putty, etc. sticks to that plastic so I can build up the thickness at the pivot points to connect a new pivoting system.
I would appreciate any thoughts on what to use to fasten a new pivot and re-inforce the surrounding area. If anyone has done this I would appreciate hearing your solution. TIA, Paul
Re: OT - Plastic Cement / Adhesive
Re: OT - Plastic Cement / Adhesive *LINK*
mikew
>Hi Paul, a relatively useful web site is at the link.
However, if I were making the repair, I would probably use some fiberglass woven cloth and epoxy to bridge the repair from the bottom.
Then on the topside, I would grind out a V-shape and fill in with ground fiberglass after the bottom is cured.
Take care, Mike
This to That--Gluing help
Bruce, a MN Galoot
>I'd take it to an auto body shop that does plastic repair and see if they can plastic weld it.
Bruce
Bill Houghton, retired fun in Sebastopol, CA
>Would it work to make a metal pivot point and bolt/rivet it to the hood instead? I've done several repairs of plastic bits this way, but it works only where the geometry permits, and some of the modern equipment, trying to look like it's ready to go on the NASCAR circuit, is too swoopy to make that easy.
It also tends to look, shall we say, country when you're done, so you do need to be comfortable with that look. Of course, for $450 I could buy myself quite a bit of comfort.
Paul Brandley
>Thank you Mike! That is a good site to be aware of. I appreciate your taking the time to respond.
Paul Brandley
>Bruce, thanks, I wasn't aware of this option. I plan to investigate it.
Paul Brandley
>Bill, that is kind of what I had in mind, but I thought I may have to beef up the surrounding area first. I'm not really worried about the looks, as long as it isn't to bad. I'll get some JD green spray paint to hide as much as I can and it is down neer the front wheels. Thanks for the response.
