A55 Smoothing Plane
Wooden plane flex
Wooden plane flex
Wooden plane flex
thomd
>I rigged up my largest jointer, a 30 inch long beech jointer with a body height of 3+ inches, and a width of 3.375 inches. I couldn't quickly rig the dial indicator near the mouth it was a little forward of that point which means the flex value would be understated, and the flex value from such a long plane would also be overstated relative to it's length relative to a standard jointer. I'm not trying to be really precise here...
I got about 5 thou flex out this p[lane. It took quite a bit of force, so that is probably comparable to the 22 inch jointer, since the same felx over a longer sole is a stiffer result but it was not right in the center. This plane does not have a forward knob, so tweaking it is not really part of the normal pattern of use, one is moreso holding it flat.
I also flexed a half roughed out jack plane blank where I could get right in the middle. it is about 18" long not trimmed and I could flex 5 thou into it with the dial over center.
I then tried the Japanese plane that I was expecting to be a banana. It flexed like a brick. This is a jointer and it was suspended over the two blocks also, so there isn't anything sneaky happening from the sole pattern. After a few pumps it flexed to about 7 thou. I don't know why it was so rigid at first, maybe the blade jamed in there had some pre-stress built in. No real idea.
What is most remarkable is that while the tests are not all that accurate there was an attempt to make similar measurements, and most of the plane were very similar in stiffness, which makes a lot of sense.
Re: Wooden plane flex
Re: flattening
paul womack
>This result (which sits very well with Doug Dawsons calculations about plane and bench flex) indicates that super-flattening longer planes is pointless.
Or (to paraphrase the great Joseph Whitworth) accuracy without rigidity is meaningless.
Of course, deflection is dramatically lower in shorter planes.
BugBear
Re: flattening
thomd
>Probably true with short metal planes, the shorter wood planes showed some deflection, though as noted deflecting them would be difficult. Also if you go back to the posts about deflection earlier on, my analysis of how it doesn't make any difference nets this stuff out, it was only an incorrect analysis if you twist the front and rear knob, which is a minority technique to say the least.
Speaking of accuraccy and flexibility.
Re: flattening
Todd O. Cronkhite Maine Native now in Jax Fl.
>Man, that's one high techy looking bow! It's almost laughable. How did such a Primitive tool evolve into something that complex?
I bet it Titaniumn, balanced, re-balanced, then stablized. The wrist angle sure dosen't look comfortable, and what's that yellow tube looking thing on the forearm?
Todd O.
Re: tech
paul womack
>Actually, bows have developed far beyond that one.
But the compound pseudo-cross-bows (they use hand-held triggers for crying out loud!) are not part of Olympic sporting archery.
BugBear
