frame and panel construction
Patrick Wheatley
>I am in the process of making a side board for my living room. It will be frame and panel construction and I have some questions. I have the legs and rails cut and sized and I am going to be marking out the groove for the panel tonight. It will be set back � inch from the edge, the groove it self will be �� by ��.
My question is, how do I go about making the groove in the legs. The rails are simple; I will use my 405 to plough straight through. The legs are a different matter, since it is a groove the starts and stops in the middle of the leg I am a little unsure what to do. Should I:
1. Define the edge of the groove with a marking gauge, then use the 405 to plough the groove extending the blade as I go. The problem I see is that the skates would get in the way on both ends.
2. Define the edges and use a chisel to cut the groove and then a router plane to clean up the bottom. The only thing I worry about with this method is not getting well defined walls for the groove.
Are there any other methods that I do not know about? I am sure I will be back with more questions; I am only at the beginning of my project after all.
Thanks for the help.
Pat
