A finishing question: alcohol disolves glaze?
Sanford
>Hi folks. I am a bit puzzled by a minor finishing glitch I had. I found that alcohol disolved a glaze that was not alcohol based. I didnt think this was supposed to happen. The story is this. I am finishing some oak in a way I have done before. I started with a water based dye, sealed it with a wash coat of shellac, put on Behlans glazing stain and let it dry. I top coated with shellac but, oops, some nasty dust fell on part when I pulled something off an overhead shelf(not the cleanest shop in the world). I figured that since the glaze was mineral spirits based (at least, that is what you use to clean up), I could just wipe off the messed up shellac and then reshellac, a couple minutes work. I was surprised when the glaze totally lifted off with the shellac. True, the glaze layer was thin and I can imagine that some of the alcohol got to the first shellac layer under the glaze. But still, the glaze itself clearly disolved into a muddy mess. Not a total disaster since I just removed it all and will reglaze tomorrow. ButI thought that a big part of the point of using shellac between layers of a finish is that everything else, at least everything that is not alcohol based,is stable under and above it allowing you to keep layers clearly apart. But this is not true if alcohol disolves the glaze. Have I missed something? Any clarification would be much appreciated -- Oh, please dont tell me to keep a cleaner shop! The Hobo spiders I have there love all the dusty corners and would be very angry if I cleaned them up. You do not want a Hobo spider angry at you. Thanks, Sanford.
