Help with darking Mahogany
Scott Burr in Ben Lomond CA
>I'm working on a G&G influenced coffee table. I want to get that nice dark color. I don't want to use stain, and the thought of attacking it with Drano doesn't appeal to me much either. Has any one tried transtint dyes or other options? I'd love to hear about them and see a pic or the results. Oh yea, I've got lots of scraps to practice on.
Re: Help with darking Mahogany
Dan Donaldson
>What problem do you have with lye? It doesn't have to be an extremely strong solution, and it does a very nice job of bringing out the nice red color. I have used it on several projects and have had no problems.
Ed Mulligan, Cape Cod
>Try lime, the stuff used for lawn care. Mix with water, apply to mahogany for a nice deep red color. Neutralize with vinegar (a mild acid), let it dry and sand lightly to remove whiskers. It's been years since I've used it so I'm not sure but I think you need to apply a clear finish to see the final color.
Ed
thomd coralseacat@yahoo.au
>Are we talking real mahogany here or the stuff they sell at HD? Real mahogany can be chemically dyed to a dark colour, as is done on the necks of many guitars. The agent is poisonous, though you are not required to imbibe it for the wood to change colour. I think the stuff is Potassium Dichromate, though I would google around on that.
Todd from San Jose
>Hi Scott,
You probably know this trick, but in case you don't...
If you're just looking for a little bit darker (to simulate a few decades of aging), you can apply boiled linseed oil or similar, in the sunshine, outdoors, and let it sit in direct sunlight for a few hours. Of course, shadows would be important, so you'd want to rotate the piece to make sure it gets direct sunlight everywhere that matters. This will darken it quite a bit, but certainly not as much as a stain or dye.
Todd
ark40
>I did a hall cabinet last year with Mahogany. I used aniline dye, I think I did a brew of three colors; Red, black and mahogany. I created several shades and chose the one LOML approved. Here's a pictures. Top coat is wipe-on poly. The cabinet comes out slightly darker in the photograph.
My problem... Just the fact that it can
>burn your eyes out and skin off. Doesn't sound like too much fun. What soluition (cut) do you use Dan?
Thanks, Scott
Real Mahogany...
>not Luan or the borg crap. Thanks, I'll Thom look into Potassium Dichromate.
Thanks Todd...
>Does it darken as much as Cherry does? I guess I should have left it outside yesterday in SJ where I'm working now. Might have melteded in the heat eh...;^)
That's awfully purdy
>Real nice work! I'm about 20 min away from the San Carlos Woodcraft store now that I'm commuting. Good excuse to go there at lunchtime.
Maybe get some other goodies besides some dyes.
Thanks for sharing!
Re: Real Mahogany...Rethink it Scott
Dave Anderson Chester, NH
>Scott, if you're concerned about the caustic properties of either lye or Drano.... forget the idea of Potassium DiChromate. It is exceptionally toxic and is absorbable through the skin if you either don't wear nitrile gloves of it gets beyond the gloves.
Perhaps Bill Tindall, who is a chemist I think, will weigh in with the full details on potassium dichromate. I personally use the lye myself and I'm very pleased with the results.
Yowza! Sounds like nadty stuff...
>Would you please walk me through the steps you go through Dave?
Re: My problem... Just the fact that it can
Dan Donaldson
>I don't measure it very exactly, but it is in the order of a spoonful in a half pint of water. If you wear goggles and rubber gloves (I use the purple ones) it is safe. Some of the finishing materials that you probably use are at least as toxic. At that concentration, you can get it on you, and as long as you rinse it off in some reasonable time (measured in at least minutes, not seconds) it won't hurt you. Obviously, that does not apply to your eyes, but the same thing can be said for varnish. It takes a little bit to darken, and if it is not dark enough, just do it again. The first coat will raise the grain, but I usually use a scotch pad to take off the nubs and it usually doesn't take off much if any of the color.
Late reply, my method
>Scott I sand to 220 grit for most woods including mahogany before starting the finishing process. I first put on an apron, eye protection, and nitrile rubber gloves. I then take a glass or plastic container (don't use metal it will corrode quickly with lye) and add a pint of water to the container. After adding the water I slowly add a heaping teaspoon of the Red Devil lye. Do NOT put the lye in the container and then add water, this can cause bubbling, frothing, and splattering and is a bit dangerous. ALWAYS ADD THE LYE TO THE WATER. I usually stir gently with a scrap of wood until the lye is completely disolved.
With a rag or a fully wet sponge generously apply the lye to the wood letting it soak in. Keep a wet edge and try not to overlap too much. Over the next minute or so the color will form and the piece will continue to darker and redden. Do not go over the areas where you applied the solution for at least 5 to 10 minutes as a reapplication will darken the wood still further. Let the wood dry for at least 12 hours. I then neutralize the wood with 3 caps full of white vinegar in a pint of water. Be very careful to dampen but not completely soak your sponge or rag. If your applicator drips onto the wood you will get nasty looking spots of discoloration and have to start the process all over again. I go over the wood with the rag only once being careful to get every area. Note that another contributor here, Sam Simpson, doesn't bother to neutralize at all and seems to get perfectly fine results. I've never tried it his way so I can't comment, but I'm more comfortable using the vinegar.
Finally I allow everything to dry for a full 24 hours before continuing the finishing process.
Dick Schafer
>Sun light will darken it to some degree. I have used trans tint mixed in alcohol and sprayed on with either a detail gun or air brush. This seems to work pretty well.
