A veneering disaster (Long)
Paul Kierstead
>I picked up a new thread, since I am diverting some from the original...
Recently I had one of those days in the shop where I was worse off (i.e. less completed) when it ended then when it started. I was trying to hammer veneer some oak veneer onto a substrate and hade some air bubbles. Here is a description of the disaster.
It is an interesting thing. I had never hammer veneered Oak before ( and will hesitate to do it again ). Interestingly enough, the air bubbles certainly weren't random; they mostly studiosly avoided the dark, rough areas of the oak and stuck to the lighter denser wood. You could actually see them follow the grain. It isn't entirely clear which bit expanded enough (either could cause the problem).
The Disaster.
I started with a carefully prepared piece of ply wood with 3/8" edging planed flush. I want the veneer to be over the edging, hence the order. We also have a quantity of 24" wide oak veneer, insanely thin, one piece (no joins).
Try #1. Heat glue. I warm the substrate some with an iron to give a little more working time. The iron is standing by. Apply glue to substrate, apply glue to veneer, flip veneer and apply glue to the other side of the veneer. Start hammering down. Now clearly it is a problem to get it all down well when doing such a large area, and I "create" a couple of problem areas my self. I get out a knife and fix those up with the iron. While I am doing that, new problem areas start to appear. And then more. As I fix them, more and more appear, often well away from where I am working. Frig. Iron is too hot as well, and now the shop smells awful. Double frig. Not what I said. Eventually, I stop in dispair an just look; there are far too many areas to fix. Get the iron, a water spritzer out and remove veneer. Bah.
Try #2. This time I thin the glue a little more for easier spreading and hoping for a little more working time. Follow same procedure, but careful to work methodically from the center out. Outside of a little lifting at the edges, I don't really create much problems directly. While just sorting an edge out a bit, wait I notice a new air bubble. Then more and more. Soon, there are quite a few, although less then try #1, it is way too many. Remove again. I am getting better at removing cleanly, if not applying ....
At this point, I only have enough veneer to do one side. Plus, I have a pretty good idea of the outcome. Hmm, I thinks, maybe some shop-made veneer, a little thicker and applied in narrower strips (only 8" wide boards) might be the order of the day. Here, we have the secondary disaster. First off, some farting with the fence previously had resulted in it not being perpendicular to the table. Hadn't noticed as normally I don't use the fence face to register. Crap, some ruined. Adjust the fence. Had done a ton of pine sawing on the BS in previous days (house stuff), the blade is pitched up, the tires a bit pitched up, and the drift angle has changed as a result. A couple more screwed up before I figure that out and eyeball a new drift angle. Then, the lack of fence height finally bites me, and the resulting veneer is not coplaner, nor consistent in thickness. Sigh. Will, it is practically usable, so long as I can flatted afterwords. The morale here is don't resaw for veneer when really pissed off and out of patience. It requires care and methodical work. Anwayay, I have enough shop veneer to do it, but it varies in thickness. I'll try it anyway, just to see the general outcome. Joint the edges of the veneer, ready to go again.
One issue here is the substrate has some irregular bits of hide glue one it. I just hope these will remelt nicely and evenly.
Try #3. I do it strip by strip. Again some edge curling, but not terribly for the other stuff. The uneven heights make it difficult, but I did the thinnest stuff, generally speaking, first, making it a little easier. A little edge curling as usual (I really need to conquer that...) but all in all, not awful. 5 min later, one of the really thin and wide ones (about 7 1/2" wide) develops a huge bubble, about 3/4" high. Sigh. I leave the shop and go get a beer and watch some Good Eats on the PVR. Return the next day. It is interesting. The narrowest one (and incidently the first one layed) has gone perfectly. It is also the best sawn one, a pretty nice even 1/16" or a tiny bit more. It is flat and even. The huge bubble remains. What has also developed is some severe distortion along the edges where they join. Clearly one piece or the other (or both) has expanded a lot in certain areas, and the edge has pushed up, mountain-formation style. Must have been nice veneer quakes in there when that happened.
Try #4 will be with the 24" wide veneer + hand pumped vacuum veneer bag + modern glue. I will return to how to do this hammer veneer style another day, but for now (in the interest of project completion) will stick to hammer veneering smaller items, or at least narrower.
Two very notable problems when doing this:
1) the large area all at once really runs the glue-gelling before your done problem. This makes it *really* hard to hammer the excess glue out from underneath. This was clearly one general problem
2) Oak really reacts to the heat and moisture of the glue, much more so then my previous stuff (mostly cherry and maple). Even pretty thick stuff reacted a fair bit.
Just thought I would share and invite and comments or thoughts.
