Pimping . . .
Pimping . . .
Pimping . . .
Steve Mackay
>Some one said I was "pimping" that 4c and I did'nt "get it". Laying in bed the other night I got it. Fruedian slip ?
Any-who . . . besides the ponce (?) wheel I don't have, how best to transfer a design onto a saw handle blank ?
Re: Pimping . . .
Most people probably...
Ted Owen, Pittsburgh
>use carbon paper to trace the outline. But I prefer to stipple--poke an awl or other sharp object through the paper to make dots on the blank, then connect the dots on the blank.
Best, Ted
Re: Pimping . . .
Re: Pimping . . .
mikew
>Hi Steve,
If I was transferring that design, I would spray adhesive the design on the blank and use an Exacto kife to incise the design into the wood. This method helps when I have trasfered carving matterns I've drawn before.
Two things--you need two copies if both sides are being done, and it helps to sand the sides to a fairly high grit first to the incised lines show well.
Then I take a v-tool and lightly deepen the lines. The paper shold sand off fairly easy if you don't use too much adhesive. I've also used those glue-sticks and a thin layer of white glue before.
Take care, Mike
Re: Pimping . . .
Glad to hear you got...
Scott Burr in Ben Lomond CA
>Pimpimg all figured out Steve. I use a light spray adhesive like 3M No. 77 spray but not so strong. I can't remember the 3M number right now.
