Thinking of taking the leap!
Brian in SLO
>So I'm having to think a about possibly moving which means a smaller workspace :(
I have been accustomed to using mostly power equipment and am thinking of selling off my Jet 6" jointer & DeWalt planer and replacing them with some nice hand planes. My reasons are both space saving and for the satisfaction I keep hearing about making curls by hand instead of the high pitched whine of the macines.
My biggest reservation is the learning curve of using hand planes as I have never really delved into this new world before. I think for what the machines will sell for I will be able to buy some nice LV planes which kinda excites me too!
I don't really know what to look for or how to learn hand planing so I'm kinda hoping for some thoughts and/or ideas before making the big plunge. Any comments or suggestions would be greatly appreciated.
I'm also posting this over in the general forum of machine users too!
Re: Thinking of taking the leap!
Tony Sade (Charleston, WV)
>I've been sliding down the hand tool slope for a bit myself, but i intend to keep at least one foot in the power tool world while I do. While I understand and admire those who can go totally without power tools, preparing stock totally by hand is awfully time consuming and a whole lot of work. I don't have a lot of time in the shop and I get my exercise elsewhere. Honestly, I can't imagine prepping say 75 bf of qswo for a table entirely by hand, so my jointer and planer aren't going anywhere. YMMV, and good luck with whatever you decide.
Tony
Re: Depends
Dave Mount
>Depends on what kind of woodworking you do, and what you want to get out of it. While all WW procedures can be done with hand tools only, some are a lot more work than others. If you make mostly small projects, then you can do everything by hand without much extra time involved. If you do bigger stuff, like casework, going to totally hand power is going to slow you down some. For some folks, that's OK because it's the experience that counts for them, not the speed. For others (me included), limitations on time push us to combine hand and power tool use.
Do you work with rough lumber or do you buy S2S stock and work from there? I ask because if you use your jointer primarily for edge jointing, that function is fairly easy to replace with handplanes without much loss of speed. However, face jointing rough stock with hand planes is much, much more time consuming than with a power jointer. Similar issues for the planer. If you are surfacing all your own stock from rough lumber, then you're looking at a serious loss of speed going to all hand work. If you only use your planer to thin down stock for special purposes, then going to only handplanes is a little more feasible.
You don't say anything about a table saw in your post. If you have a table saw, it can partially replace a planer in rough stock prep. To do this you face joint one face with hand planes, straighten one edge, and rip the other edge parallel and square. Then you rip the second face to the desired thickness (slightly over, actually) by running the stock on edge. This makes some people queasy and you shouldn't do it if it does that to you, but it's actually not any more unsafe than any other TS operation if you use the appropriate featherboards and push blocks. If the piece is wider than you can reach through coming from both sides, then just cut as deep as you can. With the reference plane established by the sawcuts, it's easy to clean things up with a hand plane. Or you can use a hand rip saw to saw off what you can't cut on the TS -- that's much easier with the table saw kerfs to guide you and 6" of the width already removed (this requires that there be some "meat" on both sides of the kerf to really work, though if there isn't that, then there's not much to clean up anyway). Alternatively, if you have a bandsaw, you can use that to do the same thing (hand planes to face and edge joint, power to make the second face parallel, cleanup with hand planes). I think there's quite a few folks that work predominately with hand planes but still have a power bandsaw. The bandsaw gets less use in shops with a table saw, but in the small shop, it's a pretty versatile tool and can be a smaller footprint replacement for many TS operations (and it can do some things a TS can't).
But, as I said before, if you mostly make small projects, or if speed isn't that important to you, then you can just go "electron free".
Have fun -- sorry you're losing your larger workspace, but glad you're seeing it as an opportunity instead of a loss.
Dave
Re: Depends
Pam Niedermayer - Austin, TX
I disagree. I think the joiner and planer are the two most undesirable power tools in a shop and are easily replaced with good hand tools. BTW, I've used both extensively in various woodworking classes at the local community college. Here's why:
1) Both require a lot of knife sharpening, often done outside your shop, thus requiring either a long, non-productive wait or the purchase of a second set of knives.
2) There is a maximum width to every joiner/planer, and if you exceed that you'll need to plane the piece by hand anyway.
3) It's exceedingly boring to stand there hour after hour feeding these two machines. At least table and band saws require more direction from the woodworker.
4) It's often difficult for beginners to properly adjust the tables and knives (And who isn't a beginner when using these tools only every 6 months or so?).
5) And then there's snipe, which causes you to throw away perfectly good wood.
6) And then there are all the fingers lost to planers and all the dust produced.
Contrast that with the infinitely variable use planes, which, btw, are a joy to use if you get good ones. It's much easier to sharpen plane blades than joiner/planer knives, much easier to clean up shavings than dust (safer for your lungs, too), and much faster to simply plane the pieces in the first place.
Now, if you need to mill your wood, and who doesn't, the table, band, and compound miter saws are much more rational tools to keep. You'll have to pry my cms from my cold, dead hands.
Pam
Give Up Woodworking:)
David Miller from Iowa
>If you are like me (and, I suspect, others on this board) you start with a few planes and saws and before you know it you hopelesly on the slippery slope and spending way more time collecting, playing, and proselytizing with/about the tools than you spend transmogrifying wood.
That said, even though I build fewer projects, I have found hand tools really increase the karma I enjoy from building a piece.
Re: Depends - long but meaty
thomd coralseacat@yahoo.au
>Hand tool woodworking is not necessarily lower space/volume than power tool woodworking. A workbench is about the size of a planer, contractor's saw and jointer. Sure you can have a small workbench, but then one is into the realm of constricting project size which is probably the simplest solution.
I tend to look at woodworking as either production or a hobby. You either are trying to make something or just have fun. If it's 100% fun then you can specialize and keep everything within a particular size. If the answer to the request "honey the kids need blanket boxes", is a hum of activity then you need some power tools or some means of keeping ahead until the next project appears. On the other hand, you could probably make violins in a closet, remember those prisoners in Colditz who built an airplane in the attic above their cells to fly out with. They did make the plane though they didn't get a chance to fly it.
I think that if you have a workbench, then you won't greatly miss a jointer. I rarely pull mine out these days. As a tool for preparing edges it is inferior to a plane, and as a means of flattening the first surface, it is inferior and not enormously more efficient. Often a relatively small amount of cleaning on the first surface will prepare it for the planer, so you aren't really stuck doing all that much grunt work. Just get the twist out and prepare a sufficient patch for the planer table and off you go. Where the hand planes shine is their ability to control the angle of the first surface far better than a jointer, allowing you to squeeze more use out of the board, or get a better angle to the figure.
Getting rid of the planer is a totally different kettle of fish. There is nothing available to the hand tool worker that will waste dry hardwood at that rate. You can use bandsaw, chain saw, axes, and adzes, but realistically what the planer does in terms of layout and stock removal is really important. Some of the "portable" planers have become too large to be portable, and about the size of smaller cast iron machines, but the smallest planers are very useful and about the size of a couple of lunchboxes. An electric hand plane at least would be useful.
I've owned 2 jointers and 5 planers over the years, and the planer is on my essential power tools list, the only other tool there is the bandsaw. I sold my cabinet table saw and a day never goes by when I don't realize how little I miss it. I wouldn't own a chopsaw, that's embarrassing. I really couldn't agree less, though with respect, with Pam's list of planer grudges:
- You would have to be a moron to loose your fingers to a planer. I give a pass to anyone putting in an 8 hour day, but the planer is one of the safest power tools around if a few minor details are attended to
- Size limits applied to every tool, and there are workarounds. It's a fair enough point but really an argument to buy big!
- I never change blades they last for years and then I just buy a new planer. OK that's how it worked out though there were other reasons for various up and downgrades. I've always had HSS blades and I don't find they need much sharpening. But if they do then you are getting a ton of work in return
- This is one case where boring is good, as far as safety and productivity is concerned, but on the other hand it comes down to the hobby/production issue. If you don't need to get the job done then why inflict the noise on yourself, if you do need to move ahead then you just have to suck it up.
- I don't worry about snipe this again is the productivity/hobby thing at play. Why is it no problem removing 1/2" of board thickness by hand but too much work removing a few thou, that's not logical. It drives you crazy in a production setting because you need to adjust your process to capture that time, but in a hand tool shop, we are gripping about a few thou!!
- It's not really difficult to adjust the knives. On my Inca they actually designed it right and it was a walk in the park. Sadly all the cheap eastern tools are designed from the Delta type dinosaur tools that are about model T ford sophistication. I used my magnetic tool rack to set my jointer knife, and it was so easy I swore I would make a mag setter, but I eventually got around to buying one when it was on sale. A lot of the portable planers use plug and play knives, which I find kinda offensive, and I won't buy them, but it's probably a good idea, and actually as a smith I could probably find something to do with the cast-off knives. I don't doubt if I get another portable it will have those knives.
About a year ago I was crying about the need to sell off a lot of tools in my shop (still a good idea), because I really could hardly move around in there, though it's about 42, by 14 with a second story. Anyway, this year I lost my boat storage and had to park a 26'x8.5' sailboat in my drive. This was starting to become a problem since I can get a summons from the city for that kind of thing. Guess what. I tidied up and now have the boat in my shop and more walk around room than before. I still have a lot of work to do, but it's amazing what one can do in a given space.
If you do get stuck without a planer, then invest in/make some serious hogging planes. They are certainly a lot of fun.
Re: Whatever floats your boat
Dave Mount
>Hi Pam--
To be clear, I'm not trying to convert you, or anyone, to having a power jointer or planer and/or to not selling units they have � to each their own. I hang around here because I like and use hand tools, so I'd be the last one to run them down. What I said was that stock prep, as in "flat, straight, and square" is much faster with a power jointer and power planer. This is a legitimate issue, particularly for someone moving from power tools to hand tools, as the original poster is contemplating. I didn't say power versions were more pleasant, safer, or anything else. While your observations about power jointers/planers may be true, or at least true in your eyes, they don't add up to handplaning being a faster way to get rough stock flat, straight, and true. Safer, quieter, less dusty? -- sure. Faster? -- no.
Best,
Dave
Dean J in MN
One thing that always strikes me when this debate comes up is the frame of reference of the persons involved.
I have found craftsmen who come from a machine background at times enter this debate with their machine shop practices in mind and try to relate this to hand work.
Others come to the debate and ask: Why 4 square stock? Must all my boards be the same thickness? Do I even have to touch the non-face side? Is it really important this edge is 90 degrees to the face?
In other words -- How much of the typical machine 4-square process can I skip and still build my piece?
For these folks, the speed difference may not be as great.
It isn't necessarily the set of tools you are using which makes you fast -- the process is just as important.
-Dean
Strenuous rebuttal
bill tindall
>"I disagree. I think the joiner and planer are the two most undesirable power tools in a shop and are easily replaced with good hand tools. " ***** I have never met a serious woodworker, or shop owner, that worked hardwood lumber who didn't own these two tools. It is doubtful they all gravitated to their decison because these tools made less efficient use of their time. When we sold lumber we offered it planed S2S for $0.15 bd.ft. extra. Anyone here willing to hand plane lumber for that price?
1) Both require a lot of knife sharpening, often done outside your shop, thus requiring either a long, non-productive wait or the purchase of a second set of knives.****This time is insignificant and an extra set of 8" jointer knives is less than $50, less than the cost of a #4 from Todd. I work as much hardwood as most any of you and I haven't sharpened jointer knives in 5 years (they do need it now). The time I spend sharpening hand tools drawfs the time I spend on planer and jointer knives. I can put more than 1000 bd ft through the planer before knife sharpening becomes necessary. That is a lot of furniture.
2) There is a maximum width to every joiner/planer, and if you exceed that you'll need to plane the piece by hand anyway.**** I have built a house full of furniture, interior woodwork including cabinets for two houses and numerous pieces for others and never hand planed a surface.
3) It's exceedingly boring to stand there hour after hour feeding these two machines. At least table and band saws require more direction from the woodworker.*** a few minutes to plane 100 bd ft of oak. It may be boreing but it don't last long till I'm on to the good stuff. And how long would it take to surface the lumber for a set of kitchen cabinets with hand tools?
4) It's often difficult for beginners to properly adjust the tables and knives (And who isn't a beginner when using these tools only every 6 months or so?).***** True enough. but learning to hand plane is no walk in the park either.
5) And then there's snipe, which causes you to throw away perfectly good wood.***I don't get snipe. No one should with a properly adjusted machine.
6) And then there are all the fingers lost to planers and all the dust produced.**** No one in our club has had a planer injury nor have I ever heard of one, but they certainly do make lots of dust.
I'll meet you any time, any place, at high noon. You bring your plane(s) (and lots of sharpening stuff, and lots of gatoraid)) and I'll bring my planer. 100 bd ft rough red oak, plane S2S at 13/16". First one to move on to making something wins. Looser cleans up the dust, which you will be left in. Ruuummmmmm! (that my machine starting.....) PS this place will need a 30 amp 220 circuit.
Slow down
Dan Clermont
>Before going nuts and selling off all of your power tools why don't you buy a plane or two and give them a go.
Way more to hand tools then shiny LN, LV's, C & W's or old Bailey/Bedrocks. You need to be able to sharpen a tool and get a good edge. You need to learn how to read grain direction.
First tool you are going to need is a nice flat bench.Trust me, it is allot easier to use some power tools to build a bench rather then hand tools alone. But this is up to you
I started out with power tools, hated them, got into hand tools and now own a Power planer, miter saw (I could live without) and a Sweet Bandsaw. I think these tools help me enjoy hand tools more. I still get to flatten one side of my board with my hand tools, thickenss the other either by resawing or power planing and finish up with my handtools.
I have built allot of large projects including a 7 foot tall closet organizer out of figured maple with just hand tools and it took me allot longer then it would have if I would have used some power tools to help along the way.
I think you could definitely do without a tablesaw but maybe hold onto the other tools for awhile or at least until you know you are 100% satisfied with your hand tool abilities and think the hand tool world is for you.
Well Bill, you said...
Scott Burr in Ben Lomond CA
>" ***** I have never met a serious woodworker, or shop owner, that worked hardwood lumber who didn't own these two tools."
You've met someone now...
I don't own a power planer or jointer. I work with mostly hardwoods and buy a lot of rough cut lumber as well as 2s2 or s4s. Sure someday I'd like to own both, I'm quite content with the way things are in my shop with out them.
Re: Strenuous rebuttal
Adam Cherubini,NJ
>I agree with Pam and disagree with my friend Bill.
Personally, I don't think planers produce finish quality surfaces. So you still need to sand or plane to make decent surfaces. So if the planer can't produce a finish quality surface, why have it? Is its job then reduced to altering the thickness of stock? And how often is that really necessary? Bill's right. If the mill will surface for you for 15 cents, why not just let them do it?
Its not like you are giving up all your power tools. I think it would be harder for most folks to give up their power saws than the planers. I sincerely doubt you will miss them.
So seriously, if you want to impress us, give up your table saw.
Adam
Joel
>I don't have any power tools except a grinder. I just don't have the space. However in my next shop there is only one tool I really really want - you guessed it - a planer.
Historically the planer was the most important power tool invention, more important than the saw mill (which is important to be sure) because it's just faster to saw than to plane and construction eats up tons of planed boards. THe saw mill was the first historically important power tool invention. The planer was the second and by the 1840's in London most wood for carpenters was already power planed. I don't know when the shift happened for cabinetmakers but it was early too. In the 1930's in London power tools were uncommon for most smaller shops and a small shop would take their rough wood to a lumber yard to be planed.
I'm not that interested in a jointer - what I want to do is hand joint the important references enough so I can stick them in a planer then go to town. will save me hours.
I knew....
bill tindall
>that statement would bring one or two of you out of the woodwork.
But to be more serious, the value of a planer or jointer will depend on the scope of work one does (or can do) as well as what activities one wishes to spend time on. I think there is no question eschewing a jointer and planer will mean that some projects will become impractical, but they could be things one doesn't have any interest in any way, or maybe not.
My daughter was over the other night. She needed a cabinet for under her kitchen counter. We skip planed some poplar, she jointed edges on the jointer(easy task for novice), and we had the panels in the clamps in short order. Thirty minutes of curing and the rgh panels went through the planer again to size them and we we ready to cut and fit. To get some practice I dovetailed the box, an unnecessary extravagance, but it is good to practice on things that don't matter. A time before that we made wainscoating for her kitchen which involved planing, jointing,resawing and molding, 75 sq.ft. in all.
I like making these kinds of things and there is a steady need for it. The machines enable it.
>The best advice we can give is based on personal experience. I've given mine. I honestly don't like power jointers and planers, based on a lot of experience using them compared to hand planes. You've given yours. And that's that. It's now up to Brian to decide for himself.
Pam
PS The best Japanese planemaker I've met is missing 3 fingers. Seems he was throwing a dai through the power planer, realized he'd made a mistake, tried to grab the dai, or something like that, lots of blood and gore.
Re: you've convinced me
>Saturday I took what was left of my planer to the land fill. It was less than 10 years old. It has set in my shop for the last 5 years with a broken main casting which was made of aluminum. The way these things are built and sold just makes me mad. So for my next project, a large bookcase, I am tackling rough cut air dried walnut with hand planes and no power planer or jointer. Reports to follow in about 6 months. I have good planes, I just have not had the desire to use them for rough wood all that much. The attempt should be very interesting.
Ernie Miller
>buy a plane and give it a try. See if you can deal with the project pace. If you have to move with a smaller shop hand tools could be the answer. as others have said you can allways start with S2S lumber. I have been wanting the Lv bevel up jack so why not start with that and if you don't like it I will buy it off you so you will be out nothing in the long run. OR if you have to go to a smaller shop you could take up turning Instant gratification! but that is going to burn some serious holes in your wallet and you will end up giving alot of round things to your friends who will quit inviting you to there birthday party after a couple years.
I've got to agree mostly...
John in New Mexico
>Especially on the safety of a planer. Properly adjusted and maintained they are very safe, reaching into one while its running is so dumb it doesn't even bear comparison to more common accidents that happen with saws and jointers.
Knife changing and adjustment is no problem, you can make a jointer jig in less than 30 min, and the lunch box planers in common use now are all indexed, if I understand it correctly. Oddly enough, you rarely see posts about setting knives, yet there's never long between intricate and lengthy discussions of the rather simple task of sharpening one's hand tools.
I use both hand planes and machines a lot, and I couldn't do without either class of tool now that I've known the conveniance of both. I would discourage Brian from blindly leaping, except it would be an excuse to upgrade to an 8" jointer in a few months. Working wood doesn't need to be an either/or proposition between power and hand. By all means try a project or two by hand alone, and if you like it, then get rid of the machines.
John
Adam Cherubini
>Pam,
I appreciate your persepective regarding posts here. I feel the same way. Bill does too, I know. But I'm thankful since this attitude ins't common elsewhere.
I've shaken hands with many many woodworkers who lost their finger tips on the jointer. It almost seems common. I think Sam Maloof talked about doing something like that. I heard that among industrial ww's, the shaper caused the most injuries. I really worry about my brother (who's a full time cabinetmaker/boat builder). I don't see how you can spend your entire life around these tools and not get bitten sooner or later. Its certainly not merely a function of training, awarness or stupidity.
Adam
>That applies to machines also, You don't want to plane all the sides you can stop early with your machines also. Though I wonder to what extent this is an urban myth, are people really planing on leaving the undersides of their drawers untouched? Sure you see it in old furniture. There is something pretty cool about looking at beautifully executed tiny drawers in a fabulous piece and finding that some box stock was receycled for the the drawer bottoms.
Re: Off topic
>Planers do produce superior quality rough lumber. My big city shop has a 60 dollar minimum to do any planing. I don't have to drive across town on 14 lane HWY with gas costing 1.20 a quart.
But anyway, the point isn't whether you can do without these tools, of course one can. the point for me is why would one if one already knew and loved them, when a planer is the size of a 24 of beer. and could be easily stored under the massive workbench one is going to need anyway.
>Well first off I give an exemption from the stupidity clause for a lot of power tools, certainly the jointer is "dangerous", whatever that means. But the planer is not, if properly used. I have hurt myself about equaly with both kinds of tools, so far never seriosuly. There are a lot of very stupid things one can do with hand tools also. If ever I have to repulse an attack to the dignity of the shop, I intend to grab one of my axes, or chisels and not try to lob the planer at them. One concept in tool use is how limited or unlimeited the geometry of the tool is. Bandsaws, particularly the type that will automatically reweld the balde for internal cuts, are classed as unlimited geometry. A hand plane is pretty limited. Chisels are pretty unlimited you can make a cut in almost any direction or to any reasonable dept. Not for nothing there is a warning on the Clark and Williams site about the blades droping through the plane. I did something similar witha a Japanese plane iron. I dropped it but luckily caught it with my foot before the edge chiped on the floor. Went back to work. After a spell I noticed that I was standing in a puddle in my Birkenstocks. Oh well stupid comes in many flavours.
If you are an occasional user of power tools you probably are at pretty heavy risk. I recomend getting some books on tool use from the UK where the EEC rules apply. Most american tools are not carefully designed for the kind of work we do. A Jointer is called a "planer" in the UK and while the US jointer is at best safe for edge work the gards on euro tools are designed for face planing also. There are significant differences in the set-up for bandsaws table saws, and so forth.
Re: Wrong machine memory
>Your wrong about the planer having whacked his three fingers. It was a mortising machine that had two full width chisels that cut the inclines for the abutments and the mouth in 1/8" cuts. The Dai was presumably in a vise with one blade coming down from the left, and the other blade coming from the right. For some reason he mistimed removing the block and one of the linear actuated knives cut the first three fingers off his right hand. Analogous to a punch press accident, and the solution of hand operated kill switches would have been equally apt. If you have a machine like that in your shop, I'm OK with your removing it.
One thing we see with these Japanese super craftsmen and others of the same skill, is an almost machine like self-programming. If your inner "machine" misses a beat, the real machine is just going to take your fingers. So one needs to get out of the robot mode when operating these machines, or have some incredibly effective safety provisions.
I think he still has that machine since some of the dai at the seminar had the marks of the mortising machine on them.
>Good points. My only problem is the S2S lumber is rarely actually S2S, which admitedly tends to be a problem for the hand planes to solve.
Dean J in MN
>Yep -- I agree -- this method of work has nothing to do with the set of tools you use.
I for one skip planing where I can. For example, the aprons on the last table I built are only planed on one face, rough on the inside and not even the same thickness. Sure made that a simple and quick project.
-Dean
