Sharpening woes and questions. [borders on long]
Joe in a Cleveland suburb
>Hello.
My A2 Hock blade and chipbreaker for my trusty old #4 finally arrived. Took over a week via USPS 1st Class. Geesh.
I'm not doing very well trying to polish it and hone it. Here's what I did last night and I spent about 1-1/2 hours doing it. Using my 1000/6000 water stone I started with the 1000 side trying to polish the back (about 1/2� to 1� worth up from the bevel � not the entire back of course). Once I had consistent scratches I moved over to the 6000 grit side (I also used a nagura on the 6000 side). I kept the stone wet with a slurry and I believe it is flat (by using drywall mesh on glass). I also used a piece of scrap wood over the iron to keep a consistent amount of pressure on the iron.
I kept doing it trying to get it really polished. I kinda gave up when I didn't see it getting any better then turned my attention to honing the bevel using the same stone and a honing jig thingy. The angle the honing jig was set was honing about 1/8� of the bevel. Not the entire bevel.
The back does not have that mirror polished look. Neither does the bevel. It will shave hair off for what that's worth. I know I can do it (get the mirror polish) because I've seen it on my chisels and ordinary Stanley irons. I put the iron in the #4 and it's set for a very fine cut. I used it on a piece of scrap Walnut. It works ok but really doesn't seem any different than the original blade that was in it. I don't think this Hock blade is nearly as sharp as I should be able to get it though. Also, btw, I think this #4 is reasonably well tuned as well.
With this Hock blade, should I/can I expect a mirror polish with a 1000/6000 stone? Is the jump from 1000 to 6000 to extreme?
I have a bunch of adhesive backed sandpaper from when I used paper to sharpen. I have P2000, 3M 15mic, 3M 50mic, 3M 120mic, and 3M 30mic paper. I also have some sheets I bought at the same time I bought the other 3M paper that has no marking on it at all. I have no idea what grit it is now. One is a grayish green color and is extremely smooth (like smooth leather) and the other is a lighter slate gray color with very minimal grit. Any clue what this stuff is anybody? I wish I remember what the two un-marked papers grits are.
I bring up the paper because I was wondering if I should use that in combination with the stone. But I don't know where those micron grits fall in around the 1000/6000 stone. Any ideas?
Thanks as usual everyone for any advice.
Joe
I came up from the basement (my shop) last night and my wife was standing at the sink facing the faucet. I told here I can�t get this sharp enough. She said I�ve never been too sharp and no matter how hard I try will never be sharp. I think she thought I was pointing at my head and not the iron. She never turned away from the sink to look�
