Birthday's a commin'...Which plane next?
Todd from San Jose
>Thanks to an upcoming birthday, and funding from a profitable garage sale, the wife is going to buy me a plane of my choice.
I've narrowed the choice down to a Lie-Nielsen #8 jointer or a #5 jack. In the end, I plan to own both, but will need to get by with one of them for a good long while.
A little about the types of work I've done, and plan to do: I've been woodworking for four years now. I've used my smoothing and block planes to fit drawers, flatten and smooth surfaces, bevel raised panel doors, Etc. Projects have been small in size, such as a Pennsylvania Spice Cabinet and a settee with cabriole legs. The next few projects are going to be bigger in size- An 18th century lowboy, a sofa table, a book case, and a large entertainment center for the bedroom. I use a mixture of power tools such as the planer and jointer (when the boards are narrow enough), in addition to hand tools. I anticipate needing to flatten boards that are wider than my jointer, on occasion. I don't anticipate the need to do a lot of edge jointing by hand, as my jointer and sliding table saw seem to suffice in this area. Let me know if you agree with that last one.
In the end, I would like to have a jack plane for rough work, a jointer for flattening, and will use my smoother for smoothing. I already have a scrub plane for the occasional really heavy duty job, and a shoulder plane.
If I get the Lie-Nielsen #5 jack, an added bonus is that I can get the high angle frog and immediately swap it into my #4 smoother. I've been wanting to get a high angle frog for my smoother to reduce tearout, since I do mostly hardwoods, sometimes figured. Lie-Nielsen will put the high angle frog in the #5 at no additional charge, if I understand their catalog correctly.
But if I get the #8 jointer, I can flatten faces much easier than I can with my short little smoother. I've read Rob Cosman's responses on the #7 Vs. the #8 in the archives, and he's a strong proponent of the bigger of the two.
Another candidate is the LV low angle jack, but I'm leaning towards the LN #5, if I get a jack.
I'm fairly convinced I'm going with the LN brand, as I'm very happy with my current LN smoother and block plane. I tend to stick with what has worked for me.
So which would you buy next, a jack or a jointer, and why?
Thanks
Todd
