I'm slidinging over to the dark Side - Long
Bart Goldberg
>Hi hand tool folks,
In my pure frustration with not having large enough machines to mill large stock, I'm reconsidering my options and decided its time to learn to use some of the hand planes I'm accumulated over the years and put them to real use.
Current project requires me to flatten some large chucks of walnut I picked up from my sawyer. 18" wide, 6 ft long, and 2 inches thick. These boards are to large to face joint on my Delta DJ-20 8" joiner, and to large to plane on my Dewalt 12" planer.
Since I don't have access to larger machines, and I have neither the cash or space for larger machines, I need to learn to hand plane this board flat.
Here's my inventory:
1) Low Angle Jack
2) 4 1/2 Smooth plane
3) Adjustable Mouth Block
4) Chisel Plane (great for removing glue)
5) 2 different size shoulder planes (for cleaning up tenons)
I started out using the low angle jack going at near right angle across the board. The board is cupped on one side and High on the other. I figured I could keep planing till I could hit both edges of the board. The low angle jack seemed to work fairly well at flatting from side to side, but not to good for the length of the board.
I'm assuming I will need to get either a fore plane or a Jointer plane to do that (or both).
Questions:
1) Does one usually flatten side to side, then along the length of a board?
2) What's the best picks of hand planes for this flattening exercise.
What I don't have yet, I will start to shop for.
Thanks
Bart
