What grit wheel for a hand grinder?
Phil Joines Krum, Tx.
>Just picked up a hand grinder that needs a new wheel. I'll be using mostly to grind carving chisels and plane irons. Whats a good grit to try?
Re: What grit wheel for a hand grinder?
Who sells thes buggers anyway
>The grinnder uses a 1"ID x 4"OD x 1" wide wheel. I can't recall seeing them in any of the catalogs. I'll try to refurbish it but it's prity well saturated with oil.
>I use an 80 grit white wheel in my grinder, but it is an 8" D x 1" wheel. You might have problems finding a 4" wheel. I would check the Lee Valley catalog first, then maybe go to some place like McMaster Carr. The 80 grit wheel removes metal fairly fast and is easy to hone afterwards. There have been several threads written about what the numbers mean on a wheel, and what numbers should be used for woodworking, so a search of the archives might bring up some good stuff.
Cleaning oil stones
Roy Anderson
>There is a good article in the articles section of this web site that talks about cleaning oil stones. You might be able to rescue what you've got. It's a simple process.
Good Luck.
Re: Who sells thes buggers anyway
Tom Price
>Check the distance from the spindle to the nearest obstruction. Although many of these old grinders came with 4" wheels, if you have at least 3" of clearance you can mount a 6" wheel. Typically, the spindles on these require an additional adaptor inside the smallest one that will come with a new wheel. I found some plastic tubing that fit at the Borg, in the plumbing dept. Or you could fabricate one from wood. I use a Veritas tool rest, I highly recommend these.
Check out the tool rest on the grinder pictured in my 'Audel's Carpenters and Builders Guide' (Vol 1). Mine is the 1942 edition. They didn't expect you to try to hold a chisel on a flimsy toolrest with no guide. Looks a lot like my setup.
- Tom
Thom D
>The are bajillians of grinding wheels sold that don't ever make it into the tool catalogs. I'm not sure where you start looking but if I was in the US it would be MSC.
http://www1.mscdirect.com/CGI/N2DRVSH
Steve Kubien
Steve Kubien
>I think the smallest thing Lee Valley sells is a 6". Though my grinder came with something close to 4", I put a 6" on it with no problem.
YMMV
Steve Kubien
>That's a prity neat jig, I may try to make one.
MSC has 6x1x1 White AO wheels from 60 to 150 grit J hardness(page 808 of the 2007 catalog). I'm leaning t'ward a 100.
Re: Cleaning oil stones
>Couldn't find the article.
Soaked it overnight in some MS. Trued the surface on the lathe. Bugger had a deep groove in the center.
Striped it down, cleaned and painted. I was surprised there was no noticeable wear on the gears. The grease had turned solid. Spins better than my tops now. The cast tool rest is broken so right now I�ll make a simple one. May try to do one like the Liberty when I have more time.
I don't like to grind stuf like carving chisels on the 8" electric. It's too touchy.
Maybe now SWMBO will be willing to sharpen her own tools. :>)
Re: Cleaning oil stones *LINK*
Roy Anderson
>It sounds like you've already got it clean enough, but here's the article anyway.
Good luck.
Cleaning Oil Stones
Peter Evans
>Go for a max of 60 grit, 46 is better. The grinder is for rapid metal removal, not polishing. For hardness, try for a max of "J", "I" is better; the lower the letter the more grit, and less bond, ie better and cooler cutting. Looking at norton 38AJVBE is a good economical choice; the Norton SG wheels from toolsforworkingwood.com are better.
If you cannot fit a 6" wheel, shift to another grinder, they are plentiful at fleamarkets. a 3/4" wheel for a hand grinder is a good idea as wel, less resistance to overcome when turning.
