Hock A2 iron and chip breaker - again.
Joe in a Cleveland suburb
>Hi.
So I finally order the subject items. When I receive them, should I flatten/polish the back of the iron and hone the bevel? I suppose so, right?
I've never owned a Hock iron. I plan to use it with either my #4 or #5 or maybe both(?).
Thanks,
Joe
Re: Hock A2 iron and chip breaker - again.
>The Hock iron should have instructions with it, unless the mail man took them. But yes, you will want to polish the back and hone the bevel. The labor involved in prepping a blade so that it is ready to use out of the box would make the cost ridiculous, besides the fact that you just can't please even 1/4 of the people. I would use the blade in the #4 mostly, because you will need your best cuts in the final smoothing. You will want to get another blade for Christmas to use in your #5 and put a very slight camber on it.
Victor P
>Iirc, Hock blades come in a neat wrapper with instructions for sharpening. Of course mine got badly torn when the tape proved stonger than the paper. Out of curiosity SWMBO got out the scotch tape and re-assembled the paper so we could read all about it... Thanks Ron
Victor in Hot & Huuuumid Houston
Ok - Thank you.
I've got two or three...
John in New Mexico
>and as I remember, they only needed a quick honing and then were ready to go. Got one chip breaker too, someday I'll replace all the Stanleys with those.
John
You got it...
Scott Burr in Ben Lomond CA
>Also check the fit between the chip breaker and the blade. The chip breaker might need a little work, but probably not. I think you'll like them.
