Securing a garter
Securing a garter
Jack Guzman from Maine
Securing a garter
>I have built several vises using wooden screws.To cause the outer jaw to move with the screw I have used a device called a garter.I chop a mortise for the garter that is tight so it has to be lightly driven in the last few centimeters.The first one of these I made became loose with differences in moisture content,so the garter falls out of it's mortise.I had to install a small screw to hold the garter in it's mortise.I don't want to permanently attach the garter so gluing is not an option. Does anyone have a method for doing this? Thanks---Jack
Re: Securing a garter
ThomD
>Why not taper it so it wedges in the mortice but not against the screw, since you want that to move freely.
>Thanks,Thom. For some reason ,that simple solution never occurred to me.---Jack
More info please
Doug Littlejohn
>on just what this 'garter' is/looks like. I am about to put some wooden screw based vises together on a bench and am not real clear on how the part you are talking about is done. Any chance you could post a picture or two?
TIA, Sherwood
Re: More info please
>Here's a picture of a garter installed. The vise screw has a groove cut into it just below the head.The garter base is curved to fit in that groove.---Jack
A better picture
>Hi Doug,
This is one I made for a face vise. I made the garter so it was just a little narrower than the groove. It only is needed to pull the jaw open when the screw is backed out.---Jack
Whoops!!! Forgot the Pic.
