Stanley #81
Stanley #81
Stanley #81
Mark in B'ham
>When I went to KY this weekend, my father gave me an old Stanley #81 scraper plane. Now I need to know what to do with it. I found some info on some other web sites that told me that the #81 was manufactured between 1909 and 1942 and is cast iron with a nickle plate and rosewood for the sole. This site, http://www.brendlers.net/oldtools/scraping/scraper.htm had a lot of info on sharpening the blade but a few questions remain. I was hoping some of y'all would know what to do.
Right now the blade is sharpened on a curve and everything I've seen so far shows a flat bevel. I know that you can put a slight curve on the edge of a plane iron to keep the edges from leaving marks, but this whole blade is curved. Was that perhaps a characteristic of the #81 as opposed to the #80? If so, what do I need to do to keep the curve right as I'm sharpening and drawing the burr?
Secondly, do I need to do anything to the sole to keep the rosewood in good repair. It seems to be solid but I haven't checked it for flatness. How much care do I need to take when I'm flattening it?
Thank's for the help.
Re: Stanley #81
For what it's worth *LINK*
Bill Houghton, fog can come back any time now, pls
>You may have found Patrick Leach's site already. His take on the 81 is below.
Patrick Leach on the 81
Re: Stanley #81
Few tips
jim reed @ tallahassee
>The #81 is a good tool. Most are found without the iron, so you are lucky. Put it in a vise and use a file to square up the edge. After it is square file it to an angle--start with 30 degrees. Use something hard (like a screwdriver body) to roll the edge over into a hook. Scrape away. As for the rosewood, make some *wood juice* using 1 part boiled linseed oil and 9 parts turpentine. Rub down the rosewood and wipe off the excess. It will keep it sliding. Your scraper collection is almost complete--just add the #83, #12, #12 1/2, and #112. Good luck with your plane.
Re: Stanley #81
Thanks Y'all
Mark in B'ham
