Re: Do I need a vapor barrier?
Bob Hutchins in central TX
>Howdy Todd!
Did you just lay plywood on the floor or did you put down some 2x4's first? If you just placed the plywood on the concrete, I'd say you are in for some moisture problems.
Several years ago, I was reading up on putting plywood on the shop floor over the concrete slab to make it easier on my legs and back. I can't remember where I read the article (I'd cite it if I could), but the author recommended laying poly down, overlapping it by a foot or so and taping it. He also recommended lapping the poly up the sides of the walls above the level of the new floor. His premise was that concrete will wick moisture from the soil and the underside of the plywood will cause it to condense instead of evaporating. He put 2x4's laid on the wide face on 24" centers and used 3/4" T&G treated plywood. IIRC, he also placed extra 2x4's to support the plywood under his heavy power tools and under his workbench.
I don't know where the author was living or if that would make a difference. Perhaps colder climes with moderate rainfall -- say Pennsylvania -- are worse than warmer climes with less rainfall -- say Texas. With Florida's relatively high average annual rainfall, I'd say you will have more moisture than I will; and I'd guess you will have more condensation there, too.
HTH
BobH, who is NOT in the shower.
