THE WOODRAT IS BACK!
Make yer own depthstop
Jim Reed @ Tallahassee
>I like to find sad planes and make them happy. This little guy came to me from overseas. It is a Record 044 marked Marples. Somehow in his long journey from factory to me, he lost his depthstop and cutters. I scrounged some cutters from the big cutter box but put off the depthstop until this morning. Heat in the shop limits my sessions. This seemed like a pretty neat project which would not take much time. I measured and cut a piece of drill rod for the post. I went to the scrap pile and found a likely candidate for the shoe. Stanley shoes (1/16")are too flimsy for me so I made this one out of some 5/32" flat stock. It is sturdy. I then clamped it in the drill press vise and drilled three successively larger holes to *sneak up* on the correct hole size. Then I chamfered the hole with a tapered reamer. Filed the end of the drill rod, hammered it in, and then peened it in the chamfered hole. All it needed then was some finish grinding and polishing. Here is the finished product. Plane is happy again.
Re: Make yer own depthstop
Good job by you -- I dig it!
Edward Damewood, Northern Alabama
Nice job!
Scott Burr in Ben Lomond, CA
>Looks like you did a fine job bringing another plane back to life.
Frank D. in Montreal
>Thanks for showing us Jim,
You make it sound so easy. Posts like that encourage us to have a go at making our own parts.
Great timing!
Denis Ch�nard, Orl�ans, Ont.
>I just happened to buy the exact same plane a couple weeks ago, and the depth stop is missing...
Question: what size rod did you use? I'm not sure as to what to use...
Thanks,
DC
Mine is
>7/32. For three days I have been hunting for my dial caliper. It finally turned up. In the meantime I used a shop trick to measure the rod. Size it to a fractional drill bit set. Works like a charm as long as your drill rod is not too special. By the way, I clamped my shoe in the vise during manfacture and it would not fit the hole. I used some #220 paper to knock off the high spots so that it would slide easily. Good luck with yours. The time to beat is 19 minutes.
Question
Bill Houghton, fog can come back any time now, pls
>I understand that peening the rod into the tapered hole keeps it from falling off, but what keeps it from slipping up the rod? Or did you taper the hole both ways, or reduce the diameter of the rod to fit into the hole?
