Saw Bench
Saw Bench
Saw Bench
Patrick Gibbons, Houston, TX
>I started making a saw bench a few years ago and it got pushed aside by other projects. Chris Schwartz' article in the recent Woodworking Magazine got me thinking about my old project again. Chris puts a strong emphasis on the optimum height being 20". I was following the plan in The Complete Woodworker which uses an 18" height. Does anyone have any experience one way or the other?
Re: Saw Bench
Re: Saw Bench - how tall are you?
Ted Shuck, Centennial, CO
>It depends on how tall you are. It should be a comfortable height so you can put one knee on it to hold down the board while the other foot is on the floor. If you have long legs, then 20" or more. If you are shorter, then 18" or less. I'm not sure how tall mine is, since it was built to fit me, not a specified height.
Regards,
Ted
Re: Saw Bench
Christopher Schwarz
>You can start at 20" and then trim it down until you're comfortable. If you go too low and you'll get a rude shock when the saw's toe hits the floor.
Chris
Re: Saw Bench
paul womack
If you're intending to follow the (sensible) strategy, don't have any near-the-floor stretchers in the design.
BugBear ...whose workbench is too high, and stretchers too low :-(
Re: Saw Bench
Pam Niedermayer - Austin, TX
>Should be easy enough to move the stretchers if you've got it upside down to trim the legs.
Pam
Re: Saw Bench
david.marcus.brown
>Kinda hard to move the stretchers when they're held in place w/ wedged thru tenons. ;-)
Re: Saw Bench
Re: Saw Bench
david.marcus.brown
>I'm 5'11" and I made my saw bench 20" tall, following Christopher's plans. I'm very happy with it. I made my top a bit longer than his specified. I haven't added the saw notch or the tray in the bottom yet.
Re: Saw Bench
>I'll admit I've never tried to disemble wedged tenons, but I thought that was a technique many used to make the piece knock down. Or maybe knock out would be a better term? :)
Pam
Re: Saw Bench
Saw notch?
Scott Burr in Ben Lomond, CA
>Sorry, I'm clueless here and most other times as well. Care to elaborate for the ignorant?
Re: Saw Bench
Re: Saw notch? *LINK*
Christopher Schwarz
>David is referring to the ripping notch, which is for supporting work as you notch out corners etc.
It is shown in the link below.
Chris
Using a Sawbench
Re: Saw Bench
Re: Saw notch?
Jim Shaver Oakville, Ont.
>Hi Chris,
Thanks for the great link!!
Take care,
Jim
Re: Saw Bench
Thanks Chris...
>I had a feeling it was something a split end so to speak.
Scott
Re: Saw Bench
paul womack
>Can't shorten the legs past the mortices - whose position is dictated by the stretcher, which was my point.
BugBear
Re: Saw Bench
>Sure you can, just fill them up with some wood and epoxy.
Pam
Re: Saw Bench
Question about the holdfast hole
Michael Recchione
>I've used one of these benches (not so prettily put together, I'll admit - just butt joints and drywall screws for the stretchers) for years, and it's very useful. The one feature I question the utility of is the holdfast on the bench. What's it for?
Basically, I hold work with my knee when I use this bench - this includes ripping long stock, crosscutting long stuff, etc. The operative phrase is "long stock". For more delicate and precise work, I use my bench. The sawbench is mostly for rough dimensioning, at least for me. So I'm wondering what you do with the holdfast.
- Mike
Re: Saw Bench
Re: Question about the holdfast hole
Christopher Schwarz
>Mike,
I should do a post about the holdfast hole. It's *not* for sawing -- I also use my knees and mass to secure the work when sawing.
The holdfast hole is for mortising. The holdfast pad lands right over the front legs. It allows you to really clamp down a piece to wail and lever on it.
Ah, one more thing. When you point the holdfast toward the rear for the sawbench and cinch it down, it's a perfect handle for toting around the sawbench. I discovered this with the prototype I built.
Chris
Re: Saw Bench
david.marcus.brown
>This is one time that my opinion differs from Chris'. Personally, I hate holding stock with my knee when sawing. I do use the holdfast when I saw. Right now, there's one holdfast at the front of the sawbench. I'm going to add a second one at the other end. Different strokes for different folks . . .
Re: Saw Bench
>It works great to hold your chopsaw in place on top of the bench.
...ducking and running...
Seriously, I don't have one of these, but I recently replaced the tops/jaws on a WorkMutt with 8/4 hard maple. I put lots of dogholes into these, because the original WorkMutt dogholes never seem to be in the right place to get an effective grip on anything. Afterwards, I discovered that a holdfast works well in these dogholes, for all sorts of things beyond holding tailed apprentices in place, not necessarily furniture joinery, which I do at my main bench. Unlike Chris's bench, I would NOT recommend mortising on the top of WorkMutt, no matter how thick you make your replacement top.
A question: On your other saw bench, the plywood one with two steps, you have a pair of parallel vertical slats attached to one side that are used for holding doors, etc., vertical to facilitate planing the edge. It seems that your saw notch should work for that function, too. Do you use it that way?
Re: Saw Bench
Christopher Schwarz
>William,
First: It's been to long since we've had a beer. I wish I could get out to the Philly area more often,
Second: I use the ripping notch for a lot of things, including wedging assemblies for planing. On page 26 of the current issue of Woodworking Magazine I'm using it to plane the top of a table base flat. I do this *all* the time. I really should concoct a blog post or article on using these suckers for things other than sawing. Honestly, I think I've only scratched the surface of their uses -- and I'm impressed.
Chris
Re: Saw Bench
david.marcus.brown
>I just used mine tonight to stack some oak in my lumber rack. It's much better than the stepstool I've been using -- much more stable and the perfect height.
Re: Saw Bench
Ah, mortising
Michael Recchione
>I usually use my main bench for mortising, but I have used my sawbench for this job a few times. When it did that, I held the work down by sitting on it :-)
- Mike
Re: Saw Bench
Re: Ah, mortising
>Yeah, me, too, but it hurt a lot. I like the holdfast idea, but have to question its placement. Granted it would be handy for the carrying function, but for mortising it seems it should be offset from the center.
Pam
Re: Saw Bench
Re: Ah, mortising
Michael Recchione
>I didn't feel any pain when I did it - and I'm not very well padded :-) I do prefer mortising at my regular bench, though. I guess it's what you get used to.
- Mike
Re: Saw Bench
Re: Ah, mortising
>Yeah, it didn't seem to bother Kingshott either. In fact, he explained that it was a useful method for gaining some sit down time in the shop. But I've done more comfortable things than sitting on a 2" board while mortising. It did encourage me to get it done quickly.
Pam
