A question in regard to modifying Japanese chisels
>I have a couple of Japanese bench chisels that I am thinking of modifying. Bascally, I would like to use them for dovetailing. The sides are too thick as they stand, and my idea is to grind away the excess steel. This should not be too difficult since the reinforcing steel is softer than the cutting steel. However I am unsure whether this procedure will significantly effect the integrity of the chisel(s).
Has any one done this, or have views on the proposed modification?
