chisel handles w/o turning
les winter
>I have a bunch of unhandled socket chisels. I don't have a lathe. I'd like to find an article about making chisel handles without turning.
Any suggestions?
thanks
Les
les winter
Any suggestions?
thanks
Les
Re: chisel handles w/o turning
Barryvabeach
>Les. I really like the shape of the marples blue chisels set. I able to do a fairly good imitation by starting with a square block, then using a block plane to cut off the corners and taper it to fit my hand. Good Luck Barry
John K in Hastings, MN
>Try this:
http://www.woodcentral.com/articles/smalser/articles_447.shtml
Bob Smalser has a 3-pt article on chisel rehab in the articles archive. The first part he does with a lathe, but part 2 shows how to do it with a rasp and spokeshave.
>part 2:
http://www.woodcentral.com/articles/support_files/articles_366b.shtml
since part 1 didn't link to it.
question
bill tindall
>Aren't we supposed to use these opportunities to buy a new tool, in this case a lathe? Seriously, making an octagonal handle does not seem difficult with hand tools.
ThomD
>It's basically the same process as turning the tapered tenon for a chair. Mark out the end at the reduced diameter, drawknife the squares and then the octagons etc...
You can turn small stuff like handles on drill presses, or even just using drill motors supported in a vise.
les winter
>Thanks. the Smalser article was the one I was looking for.
Re: question
les winter
>Buying a new tool is how I got the chisels in the first place. Now, I need to buy a new tool to fix up the other new tools. This is no slippery slope, it's free fall.
les winter
>Guess what. A tool company that I thought had been long gone, http://www.frogwoodtools.com still exists. Something like the 16th page of a yahoo search for chisel handles. Their prices seem low and they have a wide selection. they have lots of other interesting stuff as well.
Les
Although
Bill Houghton, HOT Summer in Sebastopol, CA
>the chisel handles I was able to find all seem to be for tang-type chisels, rather than socket-type.
