Ian Kirby's books
Ian Kirby's books
Ian Kirby's books
Les Winter
>Long ago, Kirby wrote or was writing a series of books on furniture making. I own one, called Down to the Line, which deals with sawing. I'd like to know if anybody has any of the others. I'm not referring to the Accurate Tablesaw or the Accurate Router which are much more recent.
thanks
Les
Re: Ian Kirby's books
Thom D
>I have one he did on cutting dovetails and another he did on sharpening.
Les Winter
>Me too. Those are the modern ones, published in the last 8 years or so. I'm looking for "Plane Perfect" which goes back to the '80's or so.
thanks
Les
Thom D
>He did some interestin stuff on planing in the early FWW. What I mostly remember was a back breaking reliance on the jointer plane for everything. Or maybe that is what I saw in it since I had a Jointer plane and not much else, at the time...
Smart guy. Never found anything he did that wasn't done better somewhere else. His bench, His veneer press, his sharpening table (that is currently holding my radial arm saw. He asks all the right questions which is 90% of the battle then comes up with second rate answers. I do enjoy reading his stuff an hope you can find this book you are after. Have you tried Amazon in the UK, or UK online booksellers?
Les Winter
>I worked with him and wrote part of The Accurate Table Saw. I found him to be very interesting and creative. I think you must consider that Kirby writes to a particular audience these days. He was very attuned to the difficulty level and the likely success of the lower end of the experience spectrum. So some of his solutions aren't the best for, say, this audience. But they help the less experienced.
He showed me some neat planing tricks, like putting a few shavings underneath the spot in a board that was slightly, just slightly hollow, to allow the smooth plane to get at it. We never discussed the "jointer is all you need" stuff.
I've tried all over and located two copies of his book "Plane Perfect" in libraries. I'm going to pursue borrowing one.
regards
Les
80's = long ago
Gerry D.
>Les,
Are you implying that the 1980's were "long ago?"
Gerry,
Who was just prescribed reading glasses and ain't none too happy about it.
Re: 80's = long ago
Les Winter
>The eye doctor told me tri-focals or vari-something and gave me an RX.
The '80's were only yesterday. Or was that the '60's?
lw
Thom D
>That must have been a wonderful experience!
Edward in Vancouver
>Picked up "The complete Dovetail" written in '99. Maybe one day I can teach myself to cut dovetails. Some good stuff, but then again some stuff that goes completely over my head like this passage: (pg 49)
Vertical mounting: To quickly locate the workpiece vertically in the vise, mark the vise cheek and the bench top with a pencil or knife line taken from the outside edge of the vise support bar. Now, when you place the workpiece tight to he support bar and aligned with the pencil or knife line, it's bound to be vertical...
That just goes waaay over my head...
Thom D
>Would you agrees that one way of getting a straight piece of wood dead vertical in you vise would be if you could accurately index the two points on the stick's edge to vertical?
Ok the bottom touches the rail at the bottom of the vise this return that point time and again with no efort. All you need to do is find a way of aligning the top of the stick. So align that with a mark on your vise and bench for three points of alignment at the top. Two points might do, but having an extra point on the bench would allow you to tell if the vise had shifted, I guess. And also give you a better chance of not making a visual alignment eror with the vise mark.
Les Winter
>Take a big square and place the fence on your workbench top to the right of your vise, with the beam vertical and pointed down. Slide it to the left until it hits the rightmost guide bar of your vice. Draw a line on the edge of your workbench, guided by the inside edge of the square. Now put the square on the top of your bench and use it to extend the vertical line horizontal on the bench surface and then on the top of the vise. If you bring your board into the vise from the right, it will hit the guide bar. Holding the edge of the board against the guide bar, swing it until it's edge aligns with your marks.
Edward J
>Well, now it's in English, but the exercise still doesn't make sense to me. (mind you I'm a full time Chef...) This exercise is to keep the workpiece perfectly square in the vise?
Uh, The 80's WERE Just Yesterday
Bob Hutchins in central TX
>but some of us have trouble remembering ALL of the '60's -- not 'cause we're too young, mind you!
BobH
Thom D
>Well perfectly vertical, using the vise for that purpose. I have the book, but I don't remember this part. Arguably a dead vertical woorkpiece makes it easier to saw dead vertical on the tails. For what that is worth.
Edward in Vancouver
>Thanks. Maybe I can understand it afterall...If I have time this weekend I'll set my goals really high and make an open box, maybe 2' x 3' out of scrap pieces of 2 x6's. This I will fill with cement and insert our much argued-over laundry tree post into.....
I watched him demonstrate it years ago *LINK*
Bill Houghton, Summer fog in Sebastopol, CA
>at some woodworking show south of San Francisco. He argued that it made sawing the pins easier, because the board would be vertical, so your cuts down the pin lines would be vertical. I've never tried it (VERY limited dovetail experience), but it makes sense and is certainly simple enough. Minimizing the inspiration to do it wrong is not a bad practice.
It only works, of course, if you've got a vise with guide bars, like a conventional Wilton/Record/Jorgensen/etc. design, or the metal screw-and-guide-bar/wooden jaw equivalent, as in link below. Not so effective with a leg vise, twin screw vise, or other vise where the edge of the board would be touching a screw, which I would think would mung up the edge of the board as it turned.
Like this one
Some of us had the same problem...
Scott Burr in Ben Lomond, CA
>With the 80's...
Depends on the generation...I guess
