ADVERTISE HERE - FREE TRIAL
Drilling Tote Holes
Drilling Tote Holes
Drilling Tote Holes
Tom MacGregor
>I've just started making my own totes to replace totally trashed ones on some K series Keen Kutters that I bought cheap for users. I call them my "Bargain Bedrocks". Drilling long small diameter holes in Bolivian Rosewood without drifting is a challange. I'm using long twist bits in a big old Delta drillpress with enough travel to go that far in one shot, but am open to any suggestions. Grandpa's brace is available, too. And BTW, a mini-gloat - looking forward to a free lecture by Garrett Hack tonight in Warren, Vermont. It's at Yestermorrow @ 7.30 in case there are any woodchucks out there within driving distance.
Re: Drilling Tote Holes
arw01
>Find a post by Jerry Nordby, he makes new totes and can tell you the secret to drilling them.
Perhaps he drills them first and then patterns the totes?
Alan
Tom . . .
Steve Mackay
>I am also contemplating this trick. I keep looking at stock and It LOOKs like we should drill the stock first. Please post if you find a method to the madness ! Thanks.
steve knight
>you newed to do it from both ends.even a bradpoint bit wanders if you try to do it all at once. it's nto the machine but the bit.
I drill them with a endmill in my mill and I can do it in a single pass. but with a bradpoint it will wander.
Tom MacGregor
>My first tote is a success, and yes, I drilled the holes before roughing out the profile. I drilled a squared up piece of stock about 1/8" wider than the finished size so that the bit entered at 90 degrees to the surface. It wandered almost 1/8", but there was enough stock to salvage it. A Veritas saddle square helped me scribe the block, I'll try scribing all the way around & drilling from both ends.
Derek Cohen (in Perth Australia)
>Drill the stock, then shape the tote around the hole. This will enable you to clamp the stock so that you are drilling vertically, which is easiers and the most controlled. You can start with a drawn outline, or just a line. Just leave the cutting of the outline until after the hole has been cut.
Re: Alright! a $200 tote
Thom D
ask Mike in Katy
Dave Thompson
>Mike Taylor made totes for years.... I bought a set of cocobolo ones from him a while back. Anyway, I can't think of anyone in the world still alive more experienced at drilling tote holes. You might pop him an e-mail.
His e-mail is at the top of the page.
http://pages.sbcglobal.net/mike_in_katy/PlaneWood/Default.htm
Re: ask Mike in Katy
steve knight
>he does it from both ends on his lathe.
