Rabbet watch II . . .
Steve Mackay
>OK, its a 45. No cutter(s). Sure is purdy though. He wants $65. Whats the verdict ? Can we get cutters for the Purdy ?
Re: Rabbet watch II . . .
Also . . .
Steve Mackay
>Sorry. it is not "japaned". Bare metal, cast with flowers and such. wondering wich model it is.
search on eBay for "45 cutter" *LINK*
Bill Houghton, finally Spring!! in Sebastopol, CA
>or "Stanley 45" to get the most comprehensive listing. Yes, irons are available. Search on "completed listings" to get an idea of prices.
I can't weigh in on the price, and you haven't given enough info to judge the type, I don't think. Is it complete? Sliding section, fence, depth gauge(s), etc? You want, in my opinion, a fence with the fine adjustment, as it allows you to re-align the fence after tightening it on the rods.
I've been told that 45s don't make as effective rabbet planes as real rabbet planes, because the skates provide less support than a true sole. 78s are so inexpensive that it's worth having one, I think, even if you get the 45, which is the Chevrolet/Ford/VW/English Ford of metal-bodied combination planes - lots of them, reliable, not too fancy. Good plow, in my experience.
Patrick Leach on the No. 45
You really need both
jim reed @ tallahassee
>a #45 and a #78 for rabbets. Nickers on planes are for carpenters and are a real bother to use. For a proper rabbet, use a 1/8 blade in your #45 and cut the shoulder. It is quick and easy--no nicker needed. Then use your #78 to plow out the waste. It goes fast. Good luck with your plane.
David Churnega
>Depends on how complete it is, be warned though that a set of cutters usually goes for $65 to $90 and that is not to mention other parts that you initially do not notice as missing.
If you do not already own a 78, by all means, get one of these first.
As far as cleaning up rabbets, I use the 90 and 92 as these give me a great deal of control.
#93 is a great finish
>to a good rabbet.
Butt, Buttt
Scott Burr in Ben Lomond, CA
>We all know what their for grooving plowing...my fave.... Sorry if I'm over-standing Ya wanna sharpem mine?
Those pesky knickers
>Those blasted knickers...gotta sharpen them, gotta find a screwdriver and set them in place...then take them up. And make sure a proud screw does not booger up your edge. All this to deal with a little scrape. Then at the end of your cut, if you don't take them up, they leave a nasty scratch in the corner. It drives me nuts. I like to score with a boxcutter--it does a much better job on the surface. As for the inside cut, my 1/8 does a great job which can be finished off with the ole trusty #93. Smoothe and clean and no knickers to fuss with.
