Rabbet plane
Rabbet plane
Rabbet plane
Edward in Vancouver
>Picked up a Stanley (No. 71?) rabbet plane at a garage sale. Never used one, so I honed up the blade and tried it out. Manged to keep my rabbets fairly straight and even, (just a chunk of spruce 2 x 4) but I noticed I had to stop and clear out the shavings that were tightly packed between the lever cap and the body with a pencil. Is this normal or have I somehow set the blade wrong? Seems to cut O.K. Also, the round steel rod (arm?) that screws into the body and holds the edge guide is a little out of true. What would be the best way of straightening it out?
Re: Rabbet plane
Re: Rabbet plane *LINK*
Bill Houghton, finally Spring!! in Sebastopol, CA
>You probably have a No. 78 (see link below titled "Patrick Leach on the No. 78").
I've always had the shavings problem too. My tricks for minimizing it are: set the iron for light cuts and reach in with a finger every few strokes to kind of stir the shavings around. I do keep a length of dowel (similar idea to the pencil) on the bench for times when the space fills up.
Stanley still sells parts for these, as far as I know - at any rate, they list them in their parts catalog (page 7, link below in the body of this e-mail because I don't know how to put in multiple links). Stanley is famous for using offbeat thread pitches on odd diameters of cap screws and other threaded parts - and then they'll go and use some stunningly common bit you can replace in any hardware store. What I would NOT do with the fence rod is screw it into the body and then try to bend it straight. Take it to your hardware store and see if it fits common thread pitches. If it does, look for a connector nut (this is a really long nut used to connect two threaded rods together), hold the connector nut firmly somehow (if you've got a metalworking vise, put it in the vise; if not, find a neighbor who does), thread in the fence rod, and gently bend until true.
If the thread pitch isn't standard, I'd buy another fence rod - not too expensive, and much simpler.
Stanley's parts page: http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=partsservice.htm&LEFT=left_partsservice.htm
Re: Rabbet plane
What I do
jim reed @ tallahassee
>First I cut the shoulder with a 1/8 blade in a #45. Then I clean out the waste with the #78. Use fine cuts. As for the bent rod, if less than 3 degrees, bend it carefully while in the body. If more than 3 degrees, it may break if bent without heat. Get a new one from Stanley. Good luck. This is a nice plane.
Re: Rabbet plane
Re: What I do
Edward J
>Thanks, gentlemen. I'll TRY to order the rod. Think I might start to enjoy using the #78, On the plus side it doesn't make any noise and takes a few seconds to set up...
Mind you Stanley of Canada isn't too gung-ho about ordering planes and spare parts. Either get a Stanley garge door opener or maybe a #5, other than that they don't want to know you. Tried to order a fore-plane few months back. Went to 8 places, 7 of them said Stanley didn't make them anymore, ditto for Footprint. One said they could order it, but it would cost CDN $190. + S & H., so I was seriously considering a LV bevel-up joiner for a hundred more, then I found a #6 Record at one of those antique places for $30.00
