BLO doesn't dry
BLO doesn't dry
BLO doesn't dry
Les Winter
>My 4 month old workbench is sticky. The BLO never really and truly dried. I tried swabbing it down with turp, but that didn't help. If I scrape it with a card scraper, I get a gummy scraping. Any suggestions would be welcomed.
thanks
les
Re: BLO doesn't dry
Was it really BLO?
Scott Burr in Ben Lomond, CA
>Sounds like it was raw oil from what your describing. I wonder if a stronger solvent would help. Wish I could be more help.
Re: BLO doesn't dry
Re: Was it really BLO?
Les Winter
>It was BLO, not just plain linseed oil. Or at least that what the can said.
thanks
Re: BLO doesn't dry
Re: BLO doesn't dry
Dave Thompson
>I've often heard this with Tried and True BLO, but never heard the rest of the story of how the user dealt with it.
Some ideas off the cuff...
- Since scraping is an option, How about planing?
- Can you take advantage of the season and move the bench out into the summer sun as a heat source.
- Depending on your final finish choice, is sealing the gummy-ness in an option?
FWIW, using generic borg BLO, I don't recall having an issue like this when I use to still use BLO. I'm kind of partial to tung oil these past many years. I did use it inside drawers once and it took about ~2 years for the stink to go away. good luck.
Re: BLO doesn't dry
solution
Les Winter
>Acetone applied with a purple scotch brite pad fixes everything.
thanks for the input
Les
Re: BLO doesn't dry
Re: solution
Thom D
>I'd try a week solution of Japan dryer.
Anyway, glad it's fixed.
Re: BLO doesn't dry
Re: solution
Les Winter
>In the end, I scraped it off. the chemicals may have helped, but what a stink. the card scraper did the dead. a new coat of Lee Valley sealer and medium luster is next.
Les
