200+ woodworking book reviews
That ain't no plane, THIS is a plane ;-)
Dan Donaldson
>I like wooden planes and they are nice for making moldings, but this one might take a bit of effort to push. ;-)
Re: That ain't no plane, THIS is a plane ;-)
Kevin F, New Zealand
>I have seen pictures of planes like that where the rope was pulled by a horse. I gather the horse could even be well enough trained to pull for the right distance, and then back up.
Cheers
Kevin
Stephen
>Where was this picture taken at?
Dave Thompson
>I figured those three alcoves were for three helpers to pull the rope. A fourth person holds the tote and pulls it back....
Yep! That's a plane
Scott Burr in Ben Lomond, CA
>I wanna be the the one that throws his body on the plane and guides it along the board, not the one(s) pulling it.
Dan Donaldson
>In this particular case, it is pulled by a waterwheel.
Dan Donaldson
>The picture was taken in Kirtland Ohio.
So it's a power tool, right?
Bill Houghton, finally Spring!! in Sebastopol, CA
>Amazing the solutions developed back then.
Re: Yep! That's a plane
McKay
>I guess that you would not have to worry about that unless you had four legs.
Heres Two Real Ones
Todd Hughes
>I have had people tell me befor that these crown molding planes were used with a rope that was pulled by means of a water wheel and have to admit to be rather doubtful of it.If you look at the photo I think you will see things must have gotten kind of exciting when the plane went off the end of the board and was still being pulled.
....I think a second wood worker or aprentice would be a more likely choice though does make for an interesting exibit I supose
Heres a couple of big Crown molders that I have and you can see the hole in the front.One is probably 1700s and the other very early 1800s. Interestingly I have never seen one of these where there were any wear in the hole like you would expect to see if a rope was used in them.I think a dowel or stick was put though it and rope put on it or they were just pulled by the stick ,..Todd
Re: Heres Two Real Ones
Dan Donaldson
>I believe that the one in the picture that I posted is still in use.
Todd Hughes
>I could be wrong but looks like a modern made repo plane to me and not an original, am sure it works fine though I would like to see how they use that powered rope on it.....Todd
>It seems to me that a water wheel would work just fine. You'd use it the same way you lift an anchor with a windlass on a ship. You wrap the tow rope twice around the rotating shaft. The master guides the plane, and the apprentice pulls on the bitter end to tighten the rope around the shaft, and backs up. When you get to the end of the board, or any time you get to going too fast, the apprentice just lets off on the tension a bit and the loops of rope loosen on the shaft and the loops of rope slip, and the plane stops.
Dan Donaldson
>I am pretty sure that this is not an original. It was set up to make these moldings for church buildings and is used instead of more modern methods just to do it the old way. I didn't get to see it work, but it is my understanding that it is still used and they said it was powered by the waterwheel. If I get back there, I will try to get behind the scenes and see what makes it tick. Kirtland is fairly close to Cleveland. Maybe someone that lives close to there can go take a look one of these days.
Waterwheels and rope
Bob Hackett
>Looking at the pics I`d say the rope action was roughly the same as you would get from a cathead/winch on either a ship or a drilling rig.
Place a couple of turns of the rope over the drum and when someone pulls on the other end of the rope is tightens around the drum and pulls whatever`s on the other end in the direction of the drum or a diverting snatch block.When you stop applying tension to the free end the rope goes slack on the drum and the action stops.
Saves alot of the muscle work by the helper and can actually be a very effective system with excellent feedback and control.
MB
