How to mount an emmert
Vlad
>I recently built a bench for my emmert clone and was wondering how you mounted your emmert. I've read 2 ways. One is where the back jaw is almost flush with the front edge of the bench, and the other is where it protrudes out somewhat. Most pictures I have seen are of the latter. However, I think the flush mounted emmert looks nicer. Is there any advantage to either mounting method?
I'd love to see a pic of a flush mounted emmert.
Thanks in advance.
Vlad
PS. My benchtop is 3 3/4" thick if that makes a difference.
Re: How to mount an emmert
>I've built wooden jaw faces for mine that wrap around the front and back jaws. Both faces drop onto the jaw from the top. These are removable, so I can replace them with other auxiliary jaws. I couldn't mount the rear jaw face if the back jaw were inset into the front edge of the base. You can see both ends of both jaws in this photo.
I needed more support for the patternmaker's vise than the original bench top provided, so I built a short extension on the bench. Not very elegant looking, but it works well.
If you inset the vise, you might also find you have problems attaching and detaching the pivoting cast auxiliary jaw, due to access problems to the round head machine screw that goes through the pin. Access depends on how thick your benchtop is. To facilitate, I replaced the machine screw with a quick release pin with a pull ring. This is a piece of sailing hardware. The photo is from the website of Annapolis Performance Sailing.
Patrick Gibbons, Houston, TX
>I mounted my Emmert clone flush with the side of my bench. I didn't shape the cutout to match the curve of the back jaw I simply removed a rectangular piece of the appropriate thickness. I've had no problems with the auxillary jaw (in truth, I've not used it more than once). I glued thick leather to the jaws and have never had any need for wooden jaws.
My clone
jim reed @ tallahassee
>was mounted proud, but just because I forgot about the edge. It works great and the extra room is welcome when I move it about. There is less chance of pinching my fingers. Good luck with yours.
Jim DeLaney, Austintown, Ohio
>Mine is mounted proud of the bench face. I'd think that mounting it flush would require cutting out a couple inches extra on each side so that it could still swivel/tilt.
For auxiliary jaws, I used half inch poplar, and put a couple magnets in the back of them. No other attachment was needed.
Jim D.
Hi Vlad...
Scott Burr in Ben Lomond, CA
>I just sent you an email on mounting one. Hope it helps!
Re: Hi Vlad...
Vlad
>Got it. It was brilliant.
Many thanks to you and everyone else.
I think I'll mount it flush.
Cheers
Vlad
Re: Hi Vlad...
Vijay
>Hi Scott.
Would you mind posting your email or send a copy of your email. I too am interested in mounting an Emmert, in my newly constructed workbench.
Thanks.
Vijay
Me too
>I picked up a clone and will be mounting it one of these months...
Vijay and Derek...
>As you wish...
Scott
Re: Hi Vlad...
Victor P
>me too.
Thanks
Victor - third V name in a row how cool.
Re: Hi Vlad...
Jim Forest
>Scott,
I just completed my bench with a 2" Birch top intending to mount my T3.2 Emmert turtleback. I think it would look nicer and be best with a flush mounted rear jaw. Please e-mail your instructions to help me decide the best mounting method.
Thanks.
Jim
