Ipe for porches & decking?
woodburnbob
>The handtool content is that last year I cut the boards with a $3 saw from my waiting garage stash...after de-rusting it, and then filing and setting the teeth. Big deal, huh.
So, last summer, I ripped up the front porch floor and layed in ipe boards. Raw, 2S, unfinished boards from the wood store. I'd read about ipe being heavy, dense, stable, rot resistent, and so on and so forth. I believe it was also called 'iron wood'... no doubt for marketing and imagery.
So, I replaced the old rotting 2X cedar with 1X ipe. I just set them in tight and left them through the Oregon fall, winter and spring. I was curious about what they'd look like this summer. If they didn't warp, buckle, twist or disintegrate, then I'd think about planing them, finishing with oil and hope they'd last the rest of my life.
What is the pronunciation of ipe? Does it rhyme with wipe, E-pay, hippy, I pee, or what?
The boards swelled and shrank through predicatable cycles for 9 months. Now they are in about the same shape as last year but for perhaps 1/4" shrink across about 5 total feet of cross-grain. Straight. No cupping.
Before I go ahead and finish up, anyone have anything to say about the wisdom of outdoor ipe for decking? I hope to replace 2 decks this summer.
By the way, ultimately, yes, I have a problem with this fir, I know. It's not an illusion, it is growing into the roof and wall. Last summer, this whole thing started because I found a small piece of dry rot in the porch floor. By the end of the week I'd removed everything from foundation up to to chest high. New studs, new siding, so on and so forth. I'm now phobic about seeing another spot of dry rot anywhere. Luckily, my vision isn't what it was.
Re: Ipe for porches & decking?
Thom D
>e-pay.
sounds like you already have your answer on the wood.
Frank D. in Montreal
>Ipe is very common up here for high-end decking.
steve knight
>the wood will outlast you. don't dry to hand plane it it needs a really high angle plane and it is a huge amount of work.
hey if you want some different colors purpleheart works well too.
commercial useage
bill tindall
>The decks for the bridges on the Virginia Creeper bike trail are Ipe. I don't know how long they have been down but they are holding up well. So, apparently what ever agency keeps up this trail thinks they are good value. (There are some nice curly ones that I have been tempted to unscrew.)
Eepay It Is
Tom Colligan, Peoria
>This Old House swears by it; though they noted that no surface treatment seems to penetrate it at all. The entire Atlantic City board walk was redone with Ipe. After 17 years they cut a few boards and noted that there was no deterioration. However, the end grain should be treated though I don't know with what. Anchorseal is not waterproof or weatherproof in my experience.
Re: Eepay It Is
>If not exposed to the sun, epoxy does well for treating end grain to minimize moisture gain and loss. For a boardwalk, I'm not sure anything would work better than raw wood, but if I wanted something other than the silver-grey leathered look, I would try rounding off all the corners, so the finish coat has less chance to crack and chip, and then apply a coat of very thin epoxy (warmed for maximum penetration), followed by a few coats of marine spar varnish with UV inhibitors. The spar varnish will have to be renewed periodically.
