Opinions on the FWW dovetail article?
Denis Ch�nard, Orl�ans, Ont.
>I liked it. Things that struck me:
- he uses a japanese saw, which is my preference
- he saws pins and tails with the board horizontal on the bench. Seems silly for tails, but makes sense for half-blind pins
- his sockets are chopped very cleanly. Are Japanese chisels that good?
- he uses a pencil for marking, which I've come to prefer (more visible). He sharpen his like a knife, I don't think that's necessary and actually could be counter-productive IMHO, a sharp pencil point will follow the mark, whereas a knife shape can veer off unless held flat against the piece (one reason why I've abandoned using knifes). A 2H or 3H pencil will remain sharp quite a long time...
- he uses a modified version of Frid's scraper trick. I tried that trick too, but ended up curling my scraper without making much of a dent in the uncut part of the half-blind pins, most probably because the kerf of a Japanese saw is so thin that only my thinnest scraper (0.4 mm, or about 1/64") would fit. I guess Frid's kerf was much wider... In any case, Swensson chops the uncut part gradually, which seems to defeat the purpose of using the scraper trick (speed)
Finally, he does a set of half-blinds in about a hour, which makes me feel good that a pro uses the same amount of time as I do...
DC
Re: Opinions on the FWW dovetail article?
paul womack
Kirby's sockets in "The complete dovetail" are also very clean. He uses Marples blue chip chisels.
BugBear
HC Sakman @ Victoria, BC
>"Are Japanese chisels that good?"
Where have you been mon cher? Viens now! ;-)
Chico...
Charles
>I have not read the article. By a 'set of half-blinds' I assume you must mean two corners for a typical drawer construction.
All I can say is that if two corners take an hour he must have been building a damn large drawer. Otherwise, that is astoundingly slow.
Thom D
>"I liked it. Things that struck me:
- he uses a japanese saw, which is my preference "
I have always use JS, until I got a Tarant independence, as you mention below thin kerf isn't always helpful anyway, and Independence cuts just as well. It isn't as nice a kerf, but the sides that are left are just fine.
"- he saws pins and tails with the board horizontal on the bench. Seems silly for tails, but makes sense for half-blind pins"
Sounds like more Japanese, a vise seems to make life easier for me. (Now that I know we are talking aobut KS, his article in FWW on body mechanics and trssles was interestig though he also has a western bench.
"- his sockets are chopped very cleanly. Are Japanese chisels that good? "
The best chisels bar none, makes no difference in the results, it's all subtle stuff. It's more the hand than the chisel by far.
"- he uses a pencil for marking, which I've come to prefer (more visible). He sharpen his like a knife, I don't think that's necessary and actually could be counter-productive IMHO, a sharp pencil point will follow the mark, whereas a knife shape can veer off unless held flat against the piece (one reason why I've abandoned using knifes). A 2H or 3H pencil will remain sharp quite a long time... "
I file the point off so that one has a rounded knife edge does everything better, gets in tighter lasts longer, follows fine. I just use this on dovetails.
"- he uses a modified version of Frid's scraper trick. I tried that trick too, but ended up curling my scraper without making much of a dent in the uncut part of the half-blind pins, most probably because the kerf of a Japanese saw is so thin that only my thinnest scraper (0.4 mm, or about 1/64") would fit. I guess Frid's kerf was much wider... In any case, Swensson chops the uncut part gradually, which seems to defeat the purpose of using the scraper trick (speed)"
Ah we are talking about Swensson. I wonder about his technique, he learned from a timber framer. If a person over here learned their cabinetmaking from a TF they would do a variety of oddball stuff that makes no sense also.
I use a putty knife just like chisel and hammer it down the side. Keep in mind Frid loved Mahogany (and walnut and cherry). I'm not planing on trying this with ebony.
"Finally, he does a set of half-blinds in about a hour, which makes me feel good that a pro uses the same amount of time as I do..."
I've heard Swensson is slow (which doesn't make it true), there was some thing in FHB about a project he took on involving a beam and it took eons to complete. He does very nice work though. Typical modern woodworking though, It's all about becoming something else than a woodworker: teacher, writer, designer, analyst.
DC
Todd Stock
>Initial pencil layout makes sense, but I use a knife to transfer the tails. I'm another IT user (#206), but I worked a few years with nothing but a Zona and my stuff looked pretty good, so I think a comfortable saw is more important that push or pull.
Yet another collection of the useful, less than useful, and just plain silly...one of the reasons for first non-renewal since Issue #1.
Thom D
>Yep I have stopped picking it up and I have a mostly complete set.
where to buy Zona?
bill tindall
>I bought one if these handy things, I know not where. I think I was on a trip somewhere, maybe Minnesota. When it gets dull where can I replace it? It may be the 2nd most used saw in the shop.
Re: where to buy Zona?
Glenn Madsen in the SF Bay area
>Rockler has 'em, but they're dirt common at almost any hobby supply place, for fairly cheap... Blister pack, IIRC.
Todd Stock
>Tower Hobbies carries the Universal (35-500) for under $6. Search on 'Zona' for the rest of their listings. Mine end up as thin scrapers when dull - the new ones are so cheap that even if I could buy replacement blades, I'd take a pass.
