Done Enough... stereo cabinet (show-n-tell)
Dave Thompson
>My projects these days are kid driven since my twin boys were born two years ago. Recent furniture projects have amounted to a QSWO diaper changing station, a cherry train table with pull out drawer carts, and this, a need-it-yesterday stereo cabinet.
One early morning I turned on some chiti chiti bang bang for the boys to keep them occupied while I went and made some coffee. Unbeknownst to me, the volume knob on our home stereo which we have never in 6 years had above 9 o�clock, was set to 3 o�clock. When the MGM lion logo came on to let out it�s little roar, the full fury of 1100 watts of chained amplifiers was let loose and sounded like the jaws of a Tyrannosaurus Rex just landed on my head. It got my sleeping wife and in-laws hopping out of bed in an instant, despite being upstairs and on the other end of the house. They came down to verify I was still in one piece. That incident and the early demise of our VCR due to foreign objects inserted into the bay, prompted me to make this project.
The panels and front door are QSWO. The top, side rails and stiles are 6/4 white ash. All of the visible joints including the door are pinned bridal joints. Can�t tell very well from these photos, but I used some < 5 degrees off tangent QSWO which results in some heavy medullary ray action. The finish is tung oil, orange shellac and beeswax... (it looks much less orange than it does in this photo).
Regarding hand tools, I really was looking forward to using my #72. To cut the 1� bevel on the top. I�ve forgotten the issue now, but I didn�t think that an initial cut with the table saw would result in a perfect joining of bevels at the corners, so I planned to clean up with the #72. Having owned this plane for 4 years now and never done anything serious with it, this was going to be it�s real debut. Unfortunately, the table saw made three perfect glass smooth 45 degree bevels in a matter of seconds. I can see why the #72 had an early extinction.
Some of the grooves were cut with a wooden plow plane. The panels were made raised with a #5 jack plane after the edges were first rabbetted. The pinned dowels were done with a MF hand drill. The hinges were set with just a chisel and a little no-name #271-like size brass router plane. The door frame was made to fit the special ordered bevel glass using a Record 2506. The cross frame which holds the two panels together are M&T with hand cut mortises (drill & chisel method). All of the tenon cheeks were trued up with an 073. Exposed tenons ends and dowels pins with a #60.5. Much of the wood was hand surface jointed with a jack plane and jointer.
The white ash used in the top had some very interesting insect tracks that appear to have been filled in with sap. They sort of resemble the tracks left by a skier who is walking up a hill with his skis on�. I thought this was a cool detail that I wanted to show off. I was afraid that if I kept planing the top to remove some surface issue that the insect ski path would get planed away. I decided I wanted to keep this defect more than I wanted a true flat surface. I used my smallest smoothers and some scrapers to work on this surface. The result is a visually flat surface, but one that if you run your hand over, the slight hollows can be felt. The insect track is prominently positioned in front of the top.
Ofcourse many electrons were used for this project too�.
Regarding function design considerations, I was most concerned about heat in this cabinet, as it houses two large class AB amps. The entire back is open for wire connection and heat loss. The top is raised by an inch to allow for heat loss. I�m glad I did this as there is a significant amount of heat that comes out of this top. It doesn�t take long for one to be able to place ones hand on the middle of the top and feel the heat through the 1.5� thick ash. The frame sits on some hidden 3� casters, so it can be rolled. The door is higher than the panels in the unlikely case I eventually place this on some heavy shag carpet and the door needs to clear.
Thanks for taking an interest.
Dave
Re: Done Enough... stereo cabinet (show-n-tell)
More photos - corner detail
Dave Thompson
>Door and side frame are pegged bridal joints
More photos - bug tracks
Dave Thompson
>Lousy photo... Sap filled bug tracks in the white ash. This track spans about 7" in the top front right corner of the cabinet.
Very nice Dave!
Dan Clermont in Burnaby
Nice design. Nicely built. and finished.
David Barnett - SW Florida
Pam Niedermayer - Austin, TX
>Nice, but where is the lock to protect the stuff from your twin urchins?
Pam
The latch.
Dave Thompson
>The door magnetically closes flush. They haven't figured out yet that it has to be pulled from the top of the door which I'm not sure if they're tall enough yet to do. I also try to not let them see me do it. I'm hoping by the time they figure it out, we won't have to worry about it.
I am still designing a handle in my head. Functionally it doesn't really need one I'm just trying to come with an excuse to use my cigar shaver...
Dave
Re: The latch.
>I was totally amazed the other day when a 3 year old was able to reach our freezer handle and open it. No stool or other height raising device. And this freezer is hard to open, like a vacuum. I give you 6 months tops. :)
Pam
Great design, Dave. I particularly like
Don in Northern Arizona
>the raised top which helps ventilation without allowing little fingers to get at the electronics. I may steal some of your ideas. We have a cat that love to eat any kind of wiring and I need to build a cat proof cabinet to hold the stereo and Tivo.
Don
Very nice Dave
Scott Burr in Ben Lomond, CA
>I like the floating top. Nice design on the cabinet and joints.
Hope it wasn't a PP&J that got put into the VCR.
I think the latch will keep 'em baffeled for a month or two.
I like the way the sides turned out
bill tindall
