LV LA Block Plane Problem
Vlad
>Good afternoon galoots,
I am finding that the mouth on the plane keeps moving closer to the blade no matter how hard I tighten the screw. More often than not on endgrain work. I don't use it every date but when I do it's a nuisance.
Never had a problem with my Stanley or my LN LA Jack. Is anyone else finding problems with this plane or am I just an anomoly. Am I pressing down too hard? Curious...
Good day.
Vlad
Re: LV LA Block Plane Problem
mikew
>Hi Vlad--never has happened on my LV block--in fact, not on any adj. mouth plane I've had.
Wonder if the bolt has backed out [don't even know if that's possible] and so is bottoming out in the nut, therefore not really tightening?
Contact LV customer service, they'll take care of you. That's what is great about our two quality new plane manufacturers--try that with Stanley...
Take care, Mike
Vlad
>This thing is about 3 years old Mike, and I don't want to return it now. Not very appropriate me thinks. I'm just curious. That's all.
V. out
mikew
>See if the bolt has backed out. Never know. If it didn't use to do it, something has happened. Maybe even look for small cracks where the bolt enters the movable piece, perhaps allowing the bolt to flex upwards. Or even perhaps the nut has begun to strip.
But like LN, LV will still handle the problem if you contact them.
Take care, Mike
Ted Shuck, Centennial, CO
>Have you checked to see if some sawdust or other crud has gotten between the base and the moveable plate? There might be something in there which is effectively "lubricating" the surface and allowing it to slip more easily.
Ted
Dan Clermont in Burnaby
>Hi Vlad,
If it never worked from the start I would suspect a milling problem.
If it worked fine and then started to act up check for gunk under the toe plate.
Nothing wrong with calling LV as I would suspect these planes have a lifetime warranty just like the LN's. Just because the plane is 3 years old doesn't mean you shouldn't be given technical support
If LV refuses to help you paint mural on it and sell it on Ebay. Maybe Todd will buy it ;)
Dan Clermont
Me too, and a theory....
Rob Brophy Niagara Falls Canada
>Hey Vlad,
Same problem here, and my plane sees daily, hard use. In fact, I'd be ashamed if Rob Lee saw the poor condition it was in. And there's no way I'm giving it up...it's the best block plane out there.
I suspect that my grip on the plane is to blame. When planing, my forefinger naturally rests on the throat adjusting knob and seems to be applying a slight force in one direction or the other...sometimes clockwise, sometimes counter clockwise. Seems kinda silly but ever since I noticed this, the throat has stopped moving.
Perhaps the throat adjusting lever on Stanley/Record/Millers Falls planes acts like a washer and stops this problem?
Rob
PS: Where have you been Vlad? Great pickin's at the fleas down here this year!!
Re: Me too, and a theory....
Alice Frampton, UK
Doubt it; I have that problem with a Stanley 60.5 all the time.
Cheers, Alf
LOL!
Vlad
>Too funny!!
I've got tears in my eyes!
V. out.
Vlad
>Perhaps we should add a lock washer to it?
v.
Tony Zaffuto
>I don't know about a lock washer, but I would try a thin friction type of washer. I believe L. (big box store) sells very thin nylon washers in a variety of sizes that would work.
Since Alf's post, I realize I also have the same problem with my 60-1/2, although not with my LV.
John in Richmond Hill, ON, CA
>I didn't have that problem with the brass knob. I added the wooden knob and ball tail and that's when I found the throat moving back. I bought some high friction discs that they sell for the magnets and stuck it to the bottom of the wooden knob and that seems to solve the problem.
js
