Hand Tool Chat Tonight 9:30 p.m. E.D.T. (GMT-4)
Re: Hand Tool Chat Tonight 9:30 p.m. E.D.T. (GMT-4)
Re: Hand Tool Chat Blows my browser
Pam Niedermayer - Austin, TX
>Wm and Dan, I can't vist the chat, crashes my browser (Firefox 1.5.0.4 on Mac 10.3.9, Java 1.4 I think). Now instead of "Java Applet Loading" I get "Applet Parachat Loaded." Then it blows.
Pam
Paul Kierstead
>Chat works pretty well on Safari (10.4.6) and it is a fairly reasonably good browser.
>Yes, it does, thanks, as you saw; but Firefox just started having problems. Seemed significant to me.
Pam
Hmmmmm
Dan Donaldson
>Not sure what is going on. I am running FF 1.5.0.4 in XP and it seems to be fine. William uses a Mac, so he might have more info. I don't know much about them, or running FF on them.
Pam, disable FlashGot extension
Andrew F in Australia
>The FlashGot extension was causing a crash on every Java page with my system (Win XP)- I disabled the extension and Firefox has worked fine ever since, can log on to chat no problems, as well as any other Java website.
Just one potential option.
Cheers,
Andrew
Re: carnivors?
>I can't help. I'm running IE on MacOS 10.1. My machine's too old, too small and too slow to run FireFox under Panther.
Re: carnivors?
Paul Kierstead
>Y'know, I am not so sure. OS X has come a long way since 10.1, and IE is hardly a lightweight. You may actually find that the newer versions are faster; generally speaking, OS X has gotten faster every release (though memory requirements aren't going down any....)
Re: carnivors?
>My G3 iMac is stuffed to the gills with 256 Mb. It would spend all it's processing power cacheing memory to disk. My son tried it on his, and strongly recommends I don't bother. I'd like to get a better computer, but I've decided I have a lot more need for a better lathe right now.
Re: Pam, disable FlashGot extension
>Thanks, Andrew, but I never got a FlashGot. Maybe something else Flash, but I can't remove my Flash stuff.
I suspect this results from a change in ParaChat, so I'd like to know what's changed, let them know that he change has mucked up at least one combination of browser/OS.
Pam
>Sorry Pam,
"FlashGot" is an extension available to Mozilla Firefox - to see if you've got it installed, go to tools:extensions and if it's installed as a FireFox extension, then you can uninstall it from there and see if it makes a change.
The other option is to start up FireFox in safe mode when you want to run the chat.
Cheers,
Andrew
>Thanks. I pretty much always run in safe mode. I checked the Firefox extensions before answering. I suspect FG is a windoze thing.
Pam
Thom D
>Why do you run in safe mode? Just curious.
Because there are bad guys out there. :)
Just curious
Dan Donaldson
>Do you mean that you run Firefox in safe mode? If so, then it doesn't matter what extensions you have because they are all disabled in safe mode. Safe mode in FF is just a mode to enable you to troubleshoot problems, and as far as I know, has nothing to do with susceptibility to anything, unless it also disables Java and all of the video modes, which I have not tried. If that is the case, then nothing would work.
As I said, a MAC may be different but I don't know. The chat room works fine for me in both IE and FF. Have you tried it in a different browser?
Interesting problem.
Re: Just curious
>Oops, sorry, I mispoke. I run the browser in what I consider safe mode, things like turning off popups, no automatic application starting, and several other things. Guess I've been out of software development too long, I thought you guys meant "safe" as a regular word, not some sort of settable option.
Pam
Re: Just curious
Dan Donaldson
>Ah, OK, I see. The only thing that I can think of is that it may be set to block Java scripts. Java has to run for the chatroom to work. If you look in the options, is java enabled?
Re: Just curious
>Yes, certainly, I never removed it. Also, Safari worked on the same Mac.
Pam
Re: Just curious
Dan Donaldson
>Hmmmm. I have no clue then. That is strange.
Re: Just curious
>Well, sit tight, that computer refused to start up this morning, has to go into the shop; so it may be some other problem. I'll let you know next week when I get it back.
Pam
Re: Just curious
Thom D
>No I meant it as Safe Mode, and since that is one of the few things I know at all, I was wondering whether it could stop me getting all these freeloaders.
Re: Just curious
>What are your freeloaders free loading? There may be some settings that are effective but less onerous than Safe Mode.
Pam
