200+ woodworking book reviews
Choosing a Jointer Plane
Jerry Draper
>I want to learn to joint boards by hand. Have very little experience with hand planes. Which type jointer would be easiest to master - bevel up or bevel down?
Thanks in advance for advice.
Re: Choosing a Jointer Plane
Dan Clermont in Burnaby
>Hi Gerry,
Your question about which Jointer is easier to "Master" depends on which one you use more often.
What length of boards are you planning to joint? Do you truly need a jointer or would a jack work?
I have a Bedrock 607 and a LN 8. Both work well and I use them both. My fave is the LN 8 but it is a pricey plane (and well woorth the dough) which required saving my gas and coffee money for a long time before I could buy one.
Cheers
Dan Clermont
Thom D
>I haven't noticed much difference in the method used with either. I'd say they are equally easy to use. I think the bevel up jointer is probably easier to set up and adjust.
Tony Zaffuto
>I'd choose a Stanley #7 with a jointer gage. Good way to get your feet wet without spending a fortune.
As far as a jointer gage, I have a "no-name" Millers Falls type that works perfectly. For the planes, I have a Stanley #7 & a #6 that I use for jointing. Don't think I paid more than $100.00 for all three components.
Dean J in MN
I think we need more information to give you sound advice on which plane you want. Do you mean face jointing a board? Edge jointing? Starting with rough lumber, or cleaning up and edge after it was milled some other way?
Bevel Up vs Bevel Down has no bearing on the above.
-Dean
Stephen Kirk in Quakertown PA
>If you search for "trueing up long edges" or for posts by me in May, you'll find an earlier thread we had on jointing and straightening long boards.
Roy Anderson
>For a novice, I would suggest smaller projects and for that a good ole #5 Stanley, well tuned, will joint just fine. You can build a very inexpensive shooting board and make well jointed boxes or small trunks or end tables.
Bigger jointers can be awkward for a beginner. And a #5 can be got for about as little as any decent plane. Besides, everyone needs a #5 even if you progress to more sophisticated jointing.
Just my opinion.
