Best way to put a camber on a plane iron?
wilbur
>I've been practicing my plane iron sharpening with some old Stanley plane irons using a set of waterstones. I've gotten pretty good at getting a sharp square edge on the plane irons -- so much so that when I use the planes, I get a nice square plane track. So I'd like to round off the edges a little.
What would be the best way to do this? Looking around, I've found these options:
1. Sharpen the bevel as normal, but put more pressure on the edges, one side at a time. I haven't been able to get a clear answer on is whether you should use a coarse (1000) grit or fine (8000) grit for this purpose.
2. Hold the plane iron perpendicular to the stone, and put a camber on, effectively destroying the sharp edge at the corners, and then resharpen the bevel as you would normally.
Thanks!
