Non Mortis hinges
Non Mortis hinges
Non Mortis hinges
John Hoffman
>I had the perfect storm of problems with non-mortis hinges I bought at Rockler. I think they are Amerock (spelling). I used the rockler drill bit contraption that centers the plunge bit into the hinge causing a hole to be centered in the opening.
Ok, so here is was happened. The drill bit came off the housing and was stuck in the wood. No problem, I attached my cordless drill and tightened the chuck to remove the bit...Well the bit break off flush. After turning the air blue, I am forced to move the hinge. I then went and sheared off 5 of the screw heads supplied with the hinges. I used hand screw driver and cordless. I was very careful. In fact one of the screw head broke in half. This caused me to have a number of metal screw bodies in the EXACT place I needed a real screw. I was told that the manufacturing of these hinges is now in China. Either way these things were not worth the aggrivation, time and cost to my project.
Anybody else have problems with this crap?? Any suggestions on where to get hardware that is worth using??
If I have any more problems I am going to have to get some regular mortis hinges and hope the holes are in different places.
Regards
JH
Re: Non Mortis hinges
Non-Mortise Hinges *LINK*
>Non-mortise hinges are a bad idea, because the walls of the mortise provide a lot of the strength of the hinge. The screws to a large part keep the hinge in the mortise.
If you are using brass screws, they are very weak, as you have discovered. When I use brass screws, I always start with a steel screw, well lubricated with wax, the same size and pitch as the final brass screw, drive it in to cut the threads, and then back it out and replace it with the brass screw, again lubricated. If you can find a square drive steel screw the right size, so much the better.
Make sure your screwdriver fits the brass screw slot exactly.
I don't know if Rockler sells VIX bits, or a clone. I would look for the VIX bits. Make sure they exactly match the size of your screws, including allowance for the bevel of the hole in the hinge.
Even with the highest quality bits, in small sizes they are easy to break off, if you are not very careful to keep the drill running perpendicular to the surface of the work. The lack of tactile feedback you get from a large, heavy and powerful drill (electric powered with a big battery, or a hand driven brace and bit) exacerbates this problem, as does the spring in the VIX bit. Getting it right takes some practice. (Practice on scrap wood with a larger diameter drill bit.) I prefer using a small eggbeater drill, but with a comfortable handle on the crank. I find that I can keep the drill running straight and true if I clamp the door upright in the vise and drill horizontally.
If all else fails, you might consider drilling the pilot holes on your drill press.
There are screw extractors that you can use to remove the broken screw heads, for example, Screw Extractors. Then, you will need a plug cutter of the same diameter. Dowels won't work as well, because screw threads don't hold well in end grain. Glue the plugs in the holes, cut them off with a flush trim saw or a paring chisel, and start over.
Re: Non-Mortise Hinges
Nick Tuzzolino
>William: You are right on the money with the above info. One note re: VIX bits/clones. Rockler sells the clones. Out of the set of three I bought (an extra set, I had the VIXs) two were out of kilter, like they were on a cam. Poor quality to say the least. It's worth going out of the way for the real VIX ones. My 2 lire.
John Hoffman
>Thanks for the info. I was not using brass screws and I had the problem with a hand screw driver, being very careful. I think the problem is that they are crap.
Could you make a recomendation on quality brand of hinges and a place to get them?
thanks
JH
Jack Guzman from Maine
>Rockler sells some good quality hinges as well as cheaper ones like you got. It depends on what you want to spend. Lee Valley sells some good hardware also. I just installed 6 sets of non-mortise Rockler hinges in a country style hutch I built out of poplar and I had no problem with the hardware. I predrill all my holes(eggbeater style drill) and wax every screw before installing by hand with a screwdriver that fits the screw.I marked the holes location with a centering punch before drilling.
I prefer mortising hinges for the reasons William gave but for this application,non mortising hinges were the only thing that would work.
The Encyclopedia of Woodworking by Ernest Joyce has a very good section on hinge installation.---Jack
