Butt chisels - Where to find?
Denis Ch�nard, Orl�ans, Ont.
>In my dovetail search for the Holy Grail, it came to my mind that butt chisels would be handy. LV sells a set of three, but the smallest is 1/2" wide. I think a 1/4" chisel would come handy, especialy for narrow pins.
I know Crown makes such a chisel, but I haven't been able to find a source in Canada. Does anyone know where I could find that animal?
Thnx,
DC
Re: Butt chisels - Where to find?
HC Sakman @ Victoria, BC
>Hi Denis,
Blade may not be as short as those, but you can always saw off the handle of an old 1/4" or any other size chisel.
This may give a little better balance when you hold the chisels by the blade. Also, grind the sides sharp, which are also very helpful.
Chico...
Thom D
>As I mentioned earlier on, I just ground the 1/2" down. It's only 1/8" off each side. There isn't much chance of pulling the temper using a decent wheel or a clean belt. This angle doesn't heat up as bad as grinding the ends, and anyway the steel is already pretty soft.
These are good chisels up to about cherry, anything harder and I would look elsewhere. Or buy them with the idea you will have to heat them and quench them then put them in the stove at 350 for a while. Interestingly you can pull and replace plastic handles just like wood.
It doesn't show up in the picture but the "1/4"" chisel has "1/2" marked on it. One can grind it to the 1/4" size without touching the lettering. If you ground it to 3/16", it might start to get messed up.
Mark Harrison -- in Brisbane, Australia
>As I've repeatedly said (I can bore for Australia on this topic :-), don't bother with Crown chisels. The steel is too soft to be useful.
