$10 Chute Board and Plane
Paul in NJ
>I was perusing through my reprint of the 1909 Edward Preston Catalog by Astragal Press the other day and noticed they were offering wooden 'Shuteing Planes'. They were the size of a trying plane (22 inches) and had a handle on the side instead of the top. I had an extra wooden jack plane and decided I would experiment with it. The handle was cracked off and clumsily attached with a screw and had some checks in the end but nothing terminal. To the plus side the blade and wedge were in good shape and also the abutments and cheeks were solid. It also was made not to use a chip breaker which I subsequently did not have to clean or tune.
This jack plane was made by the Ogontz Tool Co., a brand name used by Sandusky. Companies like Auburn, Chapin, Ohio, and Sandusky built an enormous amount of planes each year. At their peak some of these companies were making more than 50,000 planes a year. These bench planes are very common and I see them everywhere at flea markets, ebay, and antique stores for very reasonable prices. My point is I don't feel bad modifying a very common wooden plane that has seen a hard life. If you are worried about destroying a valuable plane check the makers stamp on the toe of the plane. Pollak's 'A Guide to the Makers of American Wooden Planes' is an excellent resource. You could also ask here and I am sure you would get a quick answer.
I lightly jointed the sole and right side of the plane to square them to each other. I was careful not to remove too much from the side so I would not weaken the thin area of the cheek. It didn't matter if I removed a little more from the sole which is normal maintenance for a wooden plane anyway. A wider mouth was no concern since it would be used to plane end grain. The handle came from a scrap of cherry; cut, rasped, and filed to a comfortable shape and simply attached with a little glue and two screws. I then ground off the camber on the blade, ground a new bevel, and proceeded to flatten and sharpen the blade. All of this took about three hours with the blade probably taking the most time. The chute board was made from leftover plywood and a little maple. They are pretty simple to make but you need to take care aligning the fence. There are plans for them all over the web. I waxed my plane and runner on the chute board and adjusted the blade for a light cut. It took nice shavings and was very comfortable to use.
This is a nice little project done on a rainy day that won't take too long and it won't break the bank. If I were to do it over I probably would use a try plane for a little more heft but I am happy with how this one worked out.
Paul Dzioba
