We value your privacy.
>Reading an OLD American Woodworker they shows a pattern makers set of of small squares (1", 1.5", and 2") which I am interested in for checking my dovetail cuts, and other small parts I occassionally work.
A quick search of woodcraft did not turn them up (the source in 1988)
Someone know of a carrier of such fine little tools?
Re: SMALL squiares to check dovetails, etc.. *LINK*
Christopher Schwarz
>Alan,
I've used Richard Kell's small brass square for all my small chores, including everything you describe. Plus it's great for checking planes and chisels at the grinder and even when clamped in a honing guide.
It's available from a wide variety of sources. The link below was the first one that came up.
I use the 2" for dovetails and find the 6" useful also. I also use wooden squares quite a bit. Both mine are over 20 years old and seem accurate enough.
For most dovetail work I don't lay out square lines. I started this practice after Frank Klaus' famous enjoinder "unless you are very beginer..." But my overall view is that it is actually easier not to try to cut to a line, just to let the cuts flow. Like driving a car I just look down the road, I don't try to align some part of my car to the lane lines.
David Jeske
>Enco has several models. Not real sexy but functional and not too expensive. (They have more than the ones shown here) I think Bridge City Tool Works has a small square that is at the opposite extreme. I have a Starret 4" double square that I use. I have others on the board :)
>For external square checking, I find a 3" Moore & Wright die maker's square has covered me up till now, since you can adjust the blade to make a tiny square.
Starret #14 would be the rough equivalent in the US.
>I just picked up a set at a garage sale - $10 for 2, 3, 4, and 5 or 6 inch - made in India that are pretty nice. The big square is a hairline out against my test squares. I think some of the mail order houses offer them, but not sure which.
I also have, gloat gloat, a Starrett 453 diemaker's square (also a garage sale item), that adjusts to a slight angle when needed - 2-1/2" blade, but a double square so you can adjust the blade to really short when needed (assuming you have the headroom for the part sticking out the other side. I use the angular adjustment on occasion, and it's a nice feature.
Little squares are amazingly useful, to a degree I am just beginning to learn.
>Like you, I like a square that's sized for the job. I've cut down old stanley wood and steel squares before. That's one solution.
But you can also make a wooden square for this job without too much trouble. I just got done making some wooden squares for a PW article I was working on. For that matter, you could make a fancy one with a saw blade for a tongue and a stock of your choice. LV sells these little knife blade rivets that might work well for this job. (I don't know about solid rivetting).
>I made a square like the Ulmia about 25 years ago. Just a piece of wood slip jointed into another piece of wood. I would have figured that would blow out, but it's as tight as when I first made it, which was hardly perfect but OK. Certainly solid. I guess there is always the chance wood will let you down, but it also doesn't get cold, leave rust stains on your work, not too likely to dent your work, and won't shift when you drop it on concrete.
>The more expensive of the non-metric ones is the 14D, the other is the 14A. The 14D has the far more useful (for dovetails) narrow rule, so it's easy to check flat and square in odd little spaces.
The 14D is kind of hard to find, alas, but it is incredibly cool.
