Cleaning sharpening crud
wilbur
>I'm a woodworking newbie who has discovered the joy of taking an old plane blade and sharpening it on waterstones! It was much easier than I thought, and I can't believe how sharp my plane blade is.
However, I've also discovered the agony of trying to get that black sharpening crud off of my fingers. Any hints on how to clean your hands after a round of sharpening?
Re: Cleaning sharpening crud
Joel
>I wash my hands off in the sink as best as I can. Then I wipe them off on my pants. Works well enough for me.
Joel
Ps - I typically use blue denim pants. I have tested Kahkis, and accidently my good dark gray suit. Blue denim seems to work best. I have not tried corduroy or tweed. YMMV
Thom D
>Seems worst when you are setting up tools like flatening and so forth. So once you are in the pure maintenance of edges phase it may not be too bad. Lots of water helps. If you really are having it bad wear some rubber gloves, like using silicon carbide granules just begs for gloves. Another option is barrier cream, a simplified version of which is just some cheap hand lotion, may at least keep the nails clean.
Ted Shuck
>I generally do as Joel recommends. If I'm going out with LOML though, I use a fingernail brush with some soap on it and am able to get them acceptably clean pretty quickly.
Ted
Swarfega and a nail brush  *LINK*
Angus Barclay, in New Zealand
Swarfega
Pam Niedermayer - Austin, TX
>One of those shop type hand cleaners plus warm water gets most of mine off, reveals the bloody parts (fingers keep getting pinched between blade and stone) for repair/bandaids, then apply paper towel(s).
Pam
wilbur
>Well, of course I've been washing my hands. I'm talking about the black crud that still sticks underneath my fingernails and in the ridges of my fingertips even after scrubbing and digging under my fingernails.
I'm a pediatrician, and I'm sure the parents of my patients would be a little nervous if I was examining their kid with noticiable black stuff on my fingers. I think I may be needing to get my hands cleaner than most after sharpening.
wilbur
>You may have hit on the problem -- the fact that this was a major sharpening operation. Last night I spent at least 90 minutes sharpening the plane blade I was working on. It was a blade from a Stanley #7 that I just bought off of eBay, and although it was rust free, once I started sharpening, I noticed that there were many small pits close to the edge of the blade. My guess is that this blade was pretty rusty at one point and electrolysis was used to get the rust out, leaving behind the pits. I'm stil not done yet.
My other attempt at sharpening was with a used Stanley #4 blade, and that took me about an hour. That also was an inital setup, but the blade was in better condition in tems of not having a lot of pitting.
I'm guessing that once I have this blade tuned up, resharpening wil not take a lot of time, meaning less black crud to deal with.
Clean???
jim reed @ tallahassee
>Why clean? You'll just add more tomorrow.
Kerry in FortSask, Alberta
>I've never tried it for sharpening, but for some jobs where crud gets and sticks under your fingernails one solution is - before starting take a bar of soap and scratch it with your nails to pack some soap under there. Works well for greasy automotive type jobs, but maybe it wouldn't work as well for sharpening with waterstones with all the water washing the soap away? Might be worth a try.
Cheers,
Kerry
>Ah, yes, you're on another whole level of clean, just below surgeons; so I'd ask the woodworkers among them how they get clean.
Also, while the horizontal Makita grinder makes a huge mess flinging around swarf all over me and the workshop, it is a good thing for the sorts of jobs you're doing; and you could actually wear plastic gloves and an apron to stay cleanish while using it.
Pam
Lemon juice
Jim in VA
>Not sure it will work with your particular crud, but I just found out that lemon juice works like magic to get the black off my hands after I've been carving or filing. It's really amazing!
Re: Lemon juice
>Isn't this because of the citric acid? If so, many of the orange oil type cleaners should work, too.
Pam, who can't get Bert Lancaster watching Susan Sarandon's using lemons to wash off the fish smell out of her mind
wilbur
>Ouch. "Just below surgeons"? We're _way_ cleaner than the surgeons. In fact, most pediatricians make fun of surgeons, at least behind their backs :@)
As for asking the woodworking physicians for advice -- I think that I'm the only one, at least in my area. :@)
I think I might borrow some exam gloves from work and see how much that gets in the way of sharpening.
Re: Cleaning sharpening crud...
Victor P
>I thought I might throw in scrape the insides of jalopanos after scrubbing. Nobody will ever notice the black grung with your fingers stuck in your mouth trying to sooth the burn :@)
Seriously, I'm going to be in the shop this weekend working on a couple of older planes. Will try the soap under the nails and a couple of other variations and report back on Sunday. ( assuming the CRS decease allows me )
Regards from Balmy Houston
Victor - just a mudjacking fool
Re: Cleaning sharpening crud *LINK*
Dan Donaldson
>I have also done the soap under the fingernails trick and it does help. Not sure about in a wet environment, but it wouldn't hurt. I have also used the liquid gloves and it also seems to help quite a bit.
Here is a search with a bit more info on these types of products. I can understand the issue of a Doctor having this type of problem and I hope you can find something that works for you.
Liquid Glove search
Bruce, a MN Galoot
>Do a search on this forum for John Jesseph. IIRC, he's an ologist of some kind, I think anesthesiologist. He's a whiz at windsor chairs and handtool stuff.
Bruce
walt stellwagen
>I used to work (during wwII) in a machine shop and found the soap trick kept my nails clean even when the soap was used after the nails were all scruddy. My dad learned the trick during wwI
Walt
Re: Lemon juice
wilbur
>I didn't try lemon juice, but last week my wife bought some hand soap with "essential oils of Meyer lemon and other citrus with light floral notes of lily of the valley and freesia" in it from Williams Sonoma. Whatever you think about the store, this soap really did the trick.
