Re: Confusion over grit size: LV vs. Shapton
Thom D
>Particle size is not the be all and end all of sharpening. I think at these rarified levels we can guess what is happening, and the technology exist to know what is happening, but I haven't seen a truly scientific explanation. With that caveat, I draw my own conclusions, some of which are as follows.
1) good luck getting the full value out of any of the finest available abrasive. Buffing works pretty well but morphs edges, and maintaining perfection on down through the run of different grits is pretty difficult when working with geometrically perfect surfaces, however these fine abrassives are all good, and like other fine tools it's up to the craftman to get the best results.
2) Grit size is a measurement of the particle, as far as I know. So a basketball is the same size as a basketball sized piece of quarts. The quarts is more likely to cut having a rough, hard and sharp surface. Particle size is like comparing two ten inch saw blades one with sharp 25 tpi, while the other has 12 dull teeth to the inch.
3) Grit wise a lot of sandpaper hits out of it's league. One can get sharp edges from 600 grit paper while a 600 grit stone is a different animal.
4) stones are hard right through so the substrate, is more stone, not paper. This has some effect on sharpening methods and results. However the finer mylar backed fills are pretty hard. I atill don't do most of my sandpaper sharpening right into the edge. As I might when sharpening on stones.
The boutique japanese stone market is full of people trying to match stones to particular tools. So at those levels there isn't any confidence that it's all the same, but those are pretty rarified levels and most people don't work at those levels.
The exotics are cut mostly with sanding belts, cut and sharpened, sometimes even buffed. So I wouldn't worry about sandpaper cutting those materials.
I agree with Dan that a real 8000 grit King sharpening job is formidable, and good enough for 4/10000" shavings.
