L-N Bevel Edge Chisels
R.J.Whelan (Eastern Sierra, CA)
>There have probably been reports on L-N bevel edge chisels previously and they may have been more objective and less seat-of-the-pants in nature. If so, just ignore this post as it probably won�t add anything new.
I received my new chisels on Monday and couldn't wait to get to the shop on Tuesday. I had put off building drawers for a buffet so I could give the new tools a good shake-down cruise. The drawers were comprised of cherry front (half blind) and maple sides and back (through) with a total of 96 dovetails.
I decided to leave the bevel at 30 degrees (as it came from L-N). If the majority of my work was done in very dense tropical woods I would probably increase the bevel to at least 32-34 degrees. If I wanted to use the chisels for paring I�d decrease the bevel to 23-26 degrees. Fortunately (for me) I own a lot of chisels and have the luxury of having dedicated sets for mortising, dovetailing, paring and working in very dense and abrasive wood species.
After honing the chisels on a black Arkansas stone I went to work. With my mid-quality Japanese chisels I would have touched up the bevel after every 4-5 DT's. With my new chisels I was able to get through 2 to 3 times that number. It's not that I saved all that much time (typical touch up only takes a minute or so), but I found it valuable not having my rhythm interrupted by having to stop to hone so often.
Having been a long time customer of L-N I had high expectation regarding quality - I was not disappointed.
If you are looking for a high quality chisel that costs just a bit more than the mid-priced Japanese chisels these should definitely be on your short list .... rj
Re: L-N Bevel Edge Chisels
James Watriss
>Yeah, I've been pretty impressed with the steel on mine, too.
But honestly, another thing that sets them apart from the mid-range Japanese, and way apart from Sorby... out of the box they're flat. There's no need to spend an hour or three grinding away on a coarse stone to get the back flattened. That, to me, helps justify the cost of admission.
L-N Mortise Chisels
Dan Clermont in Burnaby
>Thanks R.J
Lately I have been whacking my L-N Mortise chisels and am also amazed at how well the edge holds up. But it just keeps on cutting.
I don't own the L-N Bevel edge chisels nor do I own any Japanese chisels but I am quite impressed with the Mortise Chisels.
Also equally impressed with the Hornbeam handles. Typically I prefer dark woods on handles but these Hornbeam handles show absolutely no sign of use what so ever which I find equally amazing
Dan Clermont
david.marcus.brown
>I agree with all of your comments. My 9 chisel set arrived last week and I'm very impressed. Out of the box, the backs are flat and they're sharp enough to only need a honing. I haven't done anything to test how long they hold an edge yet but I'm sure they're up to the quality of the rest of LN's steel. The feel in the hand is great -- they're perfect for bench or dovetail work. I can see where paring handles would come in handy as they're pretty short. I haven't pounded on them but I'm going to pick up a wood-is-good mallet so I don't mangle their very nice handles.
>I've pounded on them with a mallet I made from the same species as the handles themselves. The mallet (face grain) dents a bit, but the ends of the chisel handles (end grain) show no deformation. This is as expected. I don't think you will find a wooden mallet with a smooth striking surface that will damage them, at least not when used with reasonable skill for their intended purpose. Thomas chooses and prepares his wood as carefully as he chooses and prepares his steel.
Re: L-N Mortise Chisels
>That's because they're not hornbeam, Carpinus caroliniana, which is similar in performance to beech and sugar maple. They are hophornbeam, Ostrya virginiana, which is also called ironwood in Maine, a significantly superior material for this application, if the published engineering parameters are any indication of performance.
